Add primary key servers to an external key manager
POST /security/key-managers/{uuid}/key-servers
Introduced In: 9.6
Adds key servers to a configured external key manager.
Required properties
uuid- UUID of the external key manager. -
server- Key server name.
Related ONTAP commands
security key-manager external add-servers
uuid  |
string  |
path  |
True  |
External key manager UUID  |
return_records  |
boolean  |
query  |
False  |
Request Body
| Name | Type | Description |
password  |
string  |
Password credentials for connecting with the key server. This is not audited.  |
records  |
array[records]  |
An array of key servers specified to add multiple key servers to a key manager in a single API call. Valid in POST only and not valid if   |
secondary_key_servers  |
array[string]  |
A list of the secondary key servers associated with the primary key server.  |
server  |
string  |
External key server for key management. If no port is provided, a default port of 5696 is used. Not valid in POST if   |
Example request
  "password": "password",
  "records": [
      "secondary_key_servers": [
        "string"
      "server": "keyserver1.com:5698"
    "string"
Status: 201, Created
num_records  |
integer  |
Number of records  |
records  |
array[key_server]  |
  "records": [
      "records": [
            "string"
        "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65536038  |
A maximum of 4 active key servers are allowed.  |
65536821  |
The certificate is not installed.  |
65536822  |
Multitenant key management is not supported in the current cluster version.  |
65536824  |
Multitenant key management is not supported in MetroCluster configurations.  |
65536828  |
External key management is not enabled for the SVM.  |
65536834  |
Failed to get existing key-server details for the SVM.  |
65536852  |
Failed to query supported KMIP protocol versions.  |
65536870  |
Key management servers are already configured.  |
65536871  |
Duplicate key management servers exist.  |
65536921  |
The following issues were found. Unable to execute command on KMIP server.  |
66060338  |
Unable to establish secure connection to KMIP server due to incorrect server_ca certificates.  |
66060339  |
Unable to establish secure connection to KMIP server due to incorrect client certificates.  |
66060340  |
Unable to establish secure connection to KMIP server due to Cryptsoft error.  |
href  |
string  |
_links
records
password  |
string  |
array[string]  |
server  |
string  |
key_server
password  |
string  |
records  |
array[records]  |
array[string]  |
server  |
string  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
