Create a clone of the file
POST /storage/file/clone
Introduced In: 9.6
Creates a clone of the file.
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
autodelete |
boolean |
Mark clone file for auto deletion. |
destination_path |
string |
Relative path of the clone/destination file in the volume. |
is_backup |
boolean |
Mark clone file for backup. |
overwrite_destination |
boolean |
Destination file gets overwritten. |
range |
array[string] |
List of block ranges for sub-file cloning in the format "source-file-block-number:destination-file-block-number:block-count" |
source_path |
string |
Relative path of the source file in the volume. |
volume |
Example request
"destination_path": "dest_file1, dir1/dest_file2",
"range": [
"10:10:5",
"20:20:10"
"source_path": "src_file1, dir1/src_file2, ./.snapshot/snap1/src_file3",
"volume": {
"name": "volume1",
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default, Error
href |
string |
_links
volume
name |
string |
The name of the volume. |
uuid |
string |
file_clone
File clone
autodelete |
boolean |
destination_path |
string |
is_backup |
boolean |
boolean |
range |
array[string] |
source_path |
string |
volume |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
