Create a QoS policy
POST /storage/qos/policies
Introduced In: 9.6
Creates a QoS policy.
Required properties
svm.uuidorsvm.name- The existing SVM owning the QoS policy. -
name- The name of the QoS policy. -
fixed.*oradaptive.*- Either of the fixed or adaptive parameters.
Default property values
If
fixed.*parameters are specified, then capacity.shared is set to false by default.
Related ONTAP commands
qos policy-group create -
qos adaptive-policy-group create
return_records  |
boolean  |
query  |
False  |
return_timeout  |
integer  |
query  |
False  |
Request Body
| Name | Type | Description |
adaptive  |
Adaptive QoS policy-groups define measurable service level objectives (SLOs) that adjust based on the storage object used space and the storage object allocated space.  |
fixed  |
QoS policy-groups define a fixed service level objective (SLO) for a storage object.  |
name  |
string  |
Name of the QoS policy.  |
object_count  |
integer  |
Number of objects attached to this policy.  |
svm  |
uuid  |
string  |
Example request
  "name": "extreme",
  "object_count": 0,
  "svm": {
    "name": "svm1",
Status: 202, Accepted
job  |
  "job": {
    "uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
8454147  |
The maximum limit for QoS policies has been reached.  |
8454154  |
The name specified for creating conflicts with an existing QoS policy name.  |
8454260  |
Invalid value for maximum and minimum fields. Valid values for max_throughput_iops and max_throughput_mbps combination is for the ratio of max_throughput_mbps and max_throughput_iops to be within 1 to 4096.  |
8454273  |
Invalid value for an adaptive field. Value should be non-zero.  |
8454277  |
The name specified for creating an adaptive QoS policy conflicts with an existing fixed QoS policy name.  |
8454278  |
The name specified for creating a fixed QoS policy conflicts with an existing adaptive QoS policy name.  |
href  |
string  |
_links
adaptive
absolute_min_iops  |
integer  |
Specifies the absolute minimum IOPS that is used as an override when the expected_iops is less than this value. These floors are not guaranteed on non-AFF platforms or when FabricPool tiering policies are set.  |
expected_iops  |
integer  |
Expected IOPS. Specifies the minimum expected IOPS per TB allocated based on the storage object allocated size. These floors are not guaranteed on non-AFF platforms or when FabricPool tiering policies are set.  |
peak_iops  |
integer  |
Peak IOPS. Specifies the maximum possible IOPS per TB allocated based on the storage object allocated size or the storage object used size.  |
fixed
capacity_shared  |
boolean  |
Specifies whether the capacities are shared across all objects that use this QoS policy-group. Default is false.  |
max_throughput_iops  |
integer  |
Maximum throughput defined by this policy. It is specified in terms of IOPS. 0 means no maximum throughput is enforced.  |
max_throughput_mbps  |
integer  |
Maximum throughput defined by this policy. It is specified in terms of Mbps. 0 means no maximum throughput is enforced.  |
min_throughput_iops  |
integer  |
Minimum throughput defined by this policy. It is specified in terms of IOPS. 0 means no minimum throughput is enforced. These floors are not guaranteed on non-AFF platforms or when FabricPool tiering policies are set.  |
min_throughput_mbps  |
integer  |
Minimum throughput defined by this policy. It is specified in terms of Mbps. 0 means no minimum throughput is enforced.  |
svm
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
qos_policy
adaptive  |
fixed  |
name  |
string  |
object_count  |
integer  |
svm  |
uuid  |
string  |
job_link
uuid  |
string  |
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
