Create a qtree in a FlexVol or FlexGroup volume
POST /storage/qtrees
Introduced In: 9.6
Creates a qtree in a FlexVol or a FlexGroup volume.
After a qtree is created, the new qtree is assigned an identifier. This identifier is obtained using a qtree GET request. This identifier is used in the API path for the qtree PATCH and DELETE operations.
Required properties
svm.uuidorsvm.name- Existing SVM in which to create the qtree. -
volume.uuidorvolume.name- Existing volume in which to create the qtree. -
name- Name for the qtree.
Recommended optional properties
If not specified in POST, the values are inherited from the volume.
security_style- Security style for the qtree. -
unix_permissions- UNIX permissions for the qtree. -
export_policy.name or export_policy.id- Export policy of the SVM for the qtree.
Related ONTAP commands
qtree create
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
export_policy |
Export Policy |
id |
integer |
The identifier for the qtree, unique within the qtree's volume. |
name |
string |
The name of the qtree. Required in POST; optional in PATCH. |
path |
string |
Client visible path to the qtree. This field is not available if the volume does not have a junction-path configured. Not valid in POST or PATCH. |
qos_policy |
security_style |
string |
Security style. Valid in POST or PATCH. |
svm |
Required in POST |
unix_permissions |
integer |
The UNIX permissions for the qtree. Valid in POST or PATCH. |
volume |
Required in POST |
Example request
"export_policy": {
"id": "100",
"name": "default"
"id": "1",
"name": "string",
"path": "/volume3/qtree1",
"qos_policy": {
"max_throughput_iops": "10000",
"max_throughput_mbps": "500",
"min_throughput_iops": "2000",
"min_throughput_mbps": "500",
"name": "performance",
"security_style": "string",
"svm": {
"name": "svm1",
"unix_permissions": "0755",
"volume": {
"name": "volume1",
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
917927 |
The specified volume was not found. |
918232 |
Either |
918236 |
The specified |
2621462 |
The specified SVM does not exist. |
2621706 |
The specified |
2621707 |
No SVM was specified. Either |
5242886 |
Failed to create qtree. |
5242951 |
Export Policy supplied does not belong to the specified Export Policy ID. |
5242952 |
Export Policy ID specified is invalid. |
5242953 |
Qtree name must be provided. |
href |
string |
_links
export_policy
Export Policy
id |
integer |
name |
string |
qos_policy
max_throughput_iops |
integer |
Specifies the maximum throughput in IOPS, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. |
max_throughput_mbps |
integer |
Specifies the maximum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. |
min_throughput_iops |
integer |
Specifies the minimum throughput in IOPS, 0 means none. Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH. |
min_throughput_mbps |
integer |
Specifies the minimum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. |
name |
string |
The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH. |
uuid |
string |
The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH. |
iops_raw
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
other |
integer |
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on. |
read |
integer |
Performance metric for read I/O operations. |
total |
integer |
Performance metric aggregated over all types of I/O operations. |
write |
integer |
Peformance metric for write I/O operations. |
throughput_raw
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
statistics
These are raw IOPS and throughput performance numbers. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster.
iops_raw |
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time. |
status |
string |
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled with the next closest collection and tagged with "backfilled_data". "inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "negative_delta" is returned when an expected monotonically increasing value has decreased in value. "inconsistent_old_data" is returned when one or more nodes does not have the latest data. |
throughput_raw |
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time. |
timestamp |
string |
The timestamp of the performance data. |
svm
Required in POST
name |
string |
The name of the SVM. |
uuid |
string |
volume
Required in POST
name |
string |
The name of the volume. |
uuid |
string |
qtree
A qtree is a directory at the top level of a volume to which a custom export policy (for fine-grained access control) and a quota rule can be applied, if required.
export_policy |
Export Policy |
id |
integer |
name |
string |
path |
string |
qos_policy |
security_style |
string |
svm |
Required in POST |
unix_permissions |
integer |
volume |
Required in POST |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
