Protocols nvme interfaces endpoint overview
Overview
NVMe interfaces are network interfaces configured to support an NVMe over Fabrics (NVMe-oF) protocol. The NVMe interfaces are Fibre Channel (FC) interfaces supporting an NVMe-oF data protocol. Regardless of the underlying physical and data protocol, NVMe interfaces are treated equally for host-side application configuration. This endpoint provides a consolidated view of all NVMe interfaces for the purpose of configuring host-side applications.
The NVMe interfaces REST API provides NVMe-specific information about network interfaces configured to support an NVMe-oF protocol.
NVMe interfaces must be created using the protocol-specific endpoints for FC interfaces. See POST /network/fc/interfaces . After creation, the interfaces are available via this interface.
Retrieving summary information for all NVMe interfaces
# The API:
GET /api/protocols/nvme/interfaces
# The call:
curl -X GET 'https://<mgmt-ip>/api/protocols/nvme/interfaces' -H 'accept: application/hal+json'
# The response:
"records": [
"svm": {
"uuid": "013e2c44-0d30-11e9-a684-005056bbdb14",
"name": "svm1",
"href": "/api/svm/svms/013e2c44-0d30-11e9-a684-005056bbdb14"
"uuid": "74d69872-0d30-11e9-a684-005056bbdb14",
"name": "nvme1",
"href": "/api/protocols/nvme/interfaces/74d69872-0d30-11e9-a684-005056bbdb14"
"svm": {
"name": "svm1",
"uuid": "77ded991-0d30-11e9-a684-005056bbdb14",
"name": "nvme2",
"href": "/api/protocols/nvme/interfaces/77ded991-0d30-11e9-a684-005056bbdb14"
"num_records": 2,
"href": "/api/protocols/nvme/interfaces"
Retrieving detailed information for a specific NVMe interface
# The API:
GET /api/protocols/nvme/interfaces/{uuid}
# The call:
curl -X GET 'https://<mgmt-ip>/api/protocols/nvme/interfaces/77ded991-0d30-11e9-a684-005056bbdb14' -H 'accept: application/hal+json'
# The response:
"svm": {
"name": "svm1",
"name": "nvme2",
"enabled": true,
"node": {
"name": "node1",
"uuid": "cd4d47fd-0d2e-11e9-a684-005056bbdb14",
"href": "/api/cluster/nodes/cd4d47fd-0d2e-11e9-a684-005056bbdb14"
"transport_address": "nn-0x2003005056bbdb14:pn-0x2005005056bbdb14",
"fc_interface": {
"wwnn": "20:03:00:50:56:bb:db:14",
"wwpn": "20:05:00:50:56:bb:db:14",
"port": {
"name": "1a",
"uuid": "081ec491-0d2f-11e9-a684-005056bbdb14",
"node": {
"name": "node1"
"href": "/api/network/fc/ports/081ec491-0d2f-11e9-a684-005056bbdb14"
"href": "/api/network/fc/interfaces/77ded991-0d30-11e9-a684-005056bbdb14"
