Protocols san igroups endpoint overview
Overview
An initiator group (igroup) is a collection of Fibre Channel (FC) world wide port names (WWPNs), and/or iSCSI Qualified Names (IQNs), and/or iSCSI EUIs (Extended Unique Identifiers) that identify host initiators.
Initiator groups are used to control which hosts can access specific LUNs. To grant access to a LUN from one or more hosts, create an initiator group containing the host initiator names, then create a LUN map that associates the initiator group with the LUN.
The initator group REST API allows you to create, update, delete, and discover initiator groups, and add and remove initiators that can access the target and associated LUNs. An initiator can appear in multiple initiator groups. An initiator group can be mapped to multiple LUNs. A specific initiator can be mapped to a specific LUN only once.
All initiators in an initiator group must be from the same operating system. The initiator group's operating system is specified when the initiator group is created.
When an initiator group is created, the protocol property is used to restrict member initiators to Fibre Channel (fcp), iSCSI (iscsi), or both (mixed).
Zero or more initiators can be supplied when the initiator group is created. After creation, initiators can be added or removed from the initiator group using the /protocols/san/igroups/{igroup.uuid}/initiators endpoint. See link:post-protocols-san-igroups-initiators(#-san-igroup-initiator-create)anddelete-protocols-san-igroups-initiators-.htmlPOST /protocols/san/igroups/{igroup.uuid}/initiators and [DELETE /protocols/san/igroups/{igroup.uuid}/initiators/{name}] for more details.
An FC WWPN consist of 16 hexadecimal digits grouped as 8 pairs separated by colons. The format for an iSCSI IQN is iqn.yyyy-mm.reverse_domain_name:any. The iSCSI EUI format consists of the eui. prefix followed by 16 hexadecimal characters.
Creating an initiator group with no initiators
The example initiator group is for Linux iSCSI initiators only. Note that the return_records query parameter is used to obtain the newly created initiator group in the response.
# The API:
POST /api/protocols/san/igroups
# The call:
curl -X POST 'https://<mgmt-ip>/api/protocols/san/igroups?return_records=true' -H 'accept: application/hal+json' -d '{ "svm": { "name": "svm1" }, "name": "igroup1", "os_type": "linux", "protocol": "iscsi" }'
# The response:
"num_records": 1,
"records": [
"svm": {
"uuid": "02b0dfff-aa28-11e8-a653-005056bb7072",
"name": "svm1",
"href": "/api/svm/svms/02b0dfff-aa28-11e8-a653-005056bb7072"
"uuid": "8f249e7d-ab9f-11e8-b8a3-005056bb7072",
"name": "igroup1",
"protocol": "iscsi",
"os_type": "linux",
"href": "/api/protocols/san/igroups/8f249e7d-ab9f-11e8-b8a3-005056bb7072"
Creating an initiator group with initiators
The example initiator group is for Windows. FC Protocol and iSCSI initiators are allowed. Note that the return_records query parameter is used to obtain the newly created initiator group in the response.
# The API:
# The call:
curl -X POST 'https://<mgmt-ip>/api/protocols/san/igroups?return_records=true' -H 'accept: application/hal+json' -d '{ "svm": { "name": "svm1" }, "name": "igroup2", "os_type": "windows", "protocol": "mixed", "initiators": [ { "name": "20:01:00:50:56:bb:70:72" }, { "name": "iqn.1991-05.com.ms:host1" } ] }'
# The response:
"num_records": 1,
"records": [
"svm": {
"name": "svm1",
"uuid": "abf9c39d-ab9f-11e8-b8a3-005056bb7072",
"name": "igroup2",
"initiators": [
"name": "20:01:00:50:56:bb:70:72",
"href": "/api/protocols/san/igroups/abf9c39d-ab9f-11e8-b8a3-005056bb7072/initiators/20:01:00:50:56:bb:70:72"
"name": "iqn.1991-05.com.ms:host1",
"href": "/api/protocols/san/igroups/abf9c39d-ab9f-11e8-b8a3-005056bb7072/initiators/iqn.1991-05.com.ms:host1"
"href": "/api/protocols/san/igroups/abf9c39d-ab9f-11e8-b8a3-005056bb7072"
Retrieving all initiator groups
# The API:
GET /api/protocols/san/igroups
# The call:
curl -X GET 'https://<mgmt-ip>/api/protocols/san/igroups' -H 'accept: application/hal+json'
# The response:
"records": [
"svm": {
"name": "svm1",
"name": "igroup1",
"svm": {
"name": "svm1",
"name": "igroup2",
"num_records": 2,
"href": "/api/protocols/san/igroups"
Retrieving all properties of all initiator groups
The fields query parameter is used to request all initiator group properties.
# The API:
# The call:
curl -X GET 'https://<mgmt-ip>/api/protocols/san/igroups?fields=*' -H 'accept: application/hal+json'
# The response:
"records": [
"svm": {
"name": "svm1",
"name": "igroup1",
"os_type": "linux",
"svm": {
"name": "svm1",
"name": "igroup2",
"initiators": [
"num_records": 2,
"href": "/api/protocols/san/igroups?fields=*"
Retrieving all initiator groups for Linux
The os_type query parameter is used to perform the query.
# The API:
# The call:
curl -X GET 'https://<mgmt-ip>/api/protocols/san/igroups?os_type=linux' -H 'accept: application/hal+json'
# The response:
"records": [
"svm": {
"name": "svm1",
"name": "igroup1",
"os_type": "linux",
"num_records": 1,
"href": "/api/protocols/san/igroups?os_type=linux"
Retrieving a specific initiator group
# The API:
GET /api/protocols/san/igroups/{uuid}
# The call:
curl -X GET 'https://<mgmt-ip>/api/protocols/san/igroups/8f249e7d-ab9f-11e8-b8a3-005056bb7072' -H 'accept: application/hal+json'
# The response:
"svm": {
"name": "svm1",
"name": "igroup1",
"os_type": "linux",
Retrieving LUNs mapped to a specific initiator group
The fields parameter is used to specify the desired properties.
# The API:
# The call:
curl -X GET 'https://<mgmt-ip>/api/protocols/san/igroups/8f249e7d-ab9f-11e8-b8a3-005056bb7072?fields=lun_maps' -H 'accept: application/hal+json'
# The response:
"svm": {
"name": "svm1",
"name": "igroup1",
"lun_maps": [
"logical_unit_number": 0,
"lun": {
"name": "/vol/vol1/lun1",
"uuid": "4b33ba57-c4e0-4dbb-bc47-214800d18a71",
"node": {
"name": "node1",
"uuid": "f17182af-223f-4d51-8197-2cb2146d5c4c",
"href": "/api/cluster/nodes/f17182af-223f-4d51-8197-2cb2146d5c4c"
"href": "/api/storage/luns/4b33ba57-c4e0-4dbb-bc47-214800d18a71"
Renaming an initiator group
Note that renaming an initiator group must be done in a PATCH request separate from any other modifications.
# The API:
PATCH /api/protocols/san/igroups/{uuid}
# The call:
curl -X PATCH 'https://<mgmt-ip>/api/protocols/san/igroups/8f249e7d-ab9f-11e8-b8a3-005056bb7072' -H 'accept: application/hal+json' -d '{ "name": "igroup1_newName" }'
Changing the operating system type of an initiator group
# The API:
# The call:
curl -X PATCH 'https://<mgmt-ip>/api/protocols/san/igroups/8f249e7d-ab9f-11e8-b8a3-005056bb7072' -H 'accept: application/hal+json' -d '{ "os_type": "aix" }'
Adding an initiator to an initiator group
# The API:
POST /api/protocols/san/igroups/{igroup.uuid}/initiators
# The call:
curl -X POST 'https://<mgmt-ip>/api/protocols/san/igroups/8f249e7d-ab9f-11e8-b8a3-005056bb7072/initiators' -H 'accept: application/hal+json' -d '{ "name": "iqn.1991-05.com.ms:host2" }'
Adding multiple initiators to an initiator group
Note the use of the records property to add multiple initiators to the initiator group in a single API call.
# The API:
# The call:
curl -X POST 'https://<mgmt-ip>/api/protocols/san/igroups/8f249e7d-ab9f-11e8-b8a3-005056bb7072/initiators' -H 'accept: application/hal+json' -d '{ "records": [ { "name": "iqn.1991-05.com.ms:host3" }, { "name": "iqn.1991-05.com.ms:host4" } ] }'
Removing an initiator from an initiator group
# The API:
DELETE /api/protocols/san/igroups/{igroup.uuid}/initiators/iqn.1991-05.com.ms:host3
# The call:
curl -X DELETE 'https://<mgmt-ip>/api/protocols/san/igroups/8f249e7d-ab9f-11e8-b8a3-005056bb7072/initiators/iqn.1991-05.com.ms:host3' -H 'accept: application/hal+json'
Removing an initiator from a mapped initiator group
Normally, removing an initiator from an initiator group that is mapped to a LUN is not allowed. The removal can be forced using the allow_delete_while_mapped query parameter.
# The API:
DELETE /api/protocols/san/igroups/{igroup.uuid}/initiators/iqn.1991-05.com.ms:host4
# The call:
curl -X DELETE 'https://<mgmt-ip>/api/protocols/san/igroups/8f249e7d-ab9f-11e8-b8a3-005056bb7072/initiators/iqn.1991-05.com.ms:host4?allow_delete_while_mapped=true' -H 'accept: application/hal+json'
Deleting an initiator group
# The API:
DELETE /api/protocols/san/igroups/{uuid}
# The call:
curl -X DELETE 'https://<mgmt-ip>/api/protocols/san/igroups/abf9c39d-ab9f-11e8-b8a3-005056bb7072' -H 'accept: application/hal+json'
Deleting a mapped initiator group
Normally, deleting an initiator group that is mapped to a LUN is not allowed. The deletion can be forced using the allow_delete_while_mapped query parameter.
# The API:
# The call:
curl -X DELETE 'https://<mgmt-ip>/api/protocols/san/igroups/abf9c39d-ab9f-11e8-b8a3-005056bb7072?allow_delete_while_mapped=true' -H 'accept: application/hal+json'
