REST API reference
Support EMS destinations name endpoint overview
Overview
Manages a specific instance of a destination. There are limits to the information that you can modify after a destination is created. For example, you cannot change a destination's type, but you can modify the underlying details of the type. See the documentation for /support/ems/destinations for details on the various properties in a destination.
Retrieving a specific destination instance
# API
GET /api/support/ems/destinations/snmp-traphost
# Response
200 OK
# JSON Body
"name": "snmp-traphost",
"type": "snmp",
"destination": "",
"filters": [
    "name": "default-trap-events",
        "href": "/api/support/ems/filters/default-trap-events"
    "href": "/api/support/ems/destinations/snmp-traphost"
Updating an existing destination (change of email address)
# API
PATCH /api/support/ems/destinations/test-destination
# JSON Body
"destination": "support@mycompany.com"
# Response
200 OK
Deleting an existing destination
# API
DELETE /api/support/ems/destinations/test-destination
# Response
200 OK
