Retrieve the FPolicy event configuration for all events for an SVM
GET /protocols/fpolicy/{svm.uuid}/events
Introduced In: 9.6
Retrieves FPolicy event configurations for all events for a specified SVM. ONTAP allows the creation of cluster-level FPolicy events that act as a template for all the data SVMs belonging to the cluster. These cluster-level FPolicy events are also retrieved for the specified SVM.
Related ONTAP commands
fpolicy policy event show
Learn more
file_operations.read  |
boolean  |
query  |
False  |
Filter by file_operations.read  |
file_operations.rename  |
boolean  |
query  |
False  |
Filter by file_operations.rename  |
file_operations.close  |
boolean  |
query  |
False  |
Filter by file_operations.close  |
file_operations.symlink  |
boolean  |
query  |
False  |
Filter by file_operations.symlink  |
file_operations.write  |
boolean  |
query  |
False  |
Filter by file_operations.write  |
file_operations.link  |
boolean  |
query  |
False  |
Filter by file_operations.link  |
file_operations.delete_dir  |
boolean  |
query  |
False  |
Filter by file_operations.delete_dir  |
file_operations.lookup  |
boolean  |
query  |
False  |
Filter by file_operations.lookup  |
file_operations.rename_dir  |
boolean  |
query  |
False  |
Filter by file_operations.rename_dir  |
file_operations.getattr  |
boolean  |
query  |
False  |
Filter by file_operations.getattr  |
file_operations.setattr  |
boolean  |
query  |
False  |
Filter by file_operations.setattr  |
file_operations.create_dir  |
boolean  |
query  |
False  |
Filter by file_operations.create_dir  |
file_operations.delete  |
boolean  |
query  |
False  |
Filter by file_operations.delete  |
file_operations.open  |
boolean  |
query  |
False  |
Filter by file_operations.open  |
file_operations.create  |
boolean  |
query  |
False  |
Filter by file_operations.create  |
protocol  |
string  |
query  |
False  |
Filter by protocol  |
volume_monitoring  |
boolean  |
query  |
False  |
Filter by volume_monitoring  |
filters.setattr_with_access_time_change  |
boolean  |
query  |
False  |
Filter by filters.setattr_with_access_time_change  |
filters.setattr_with_sacl_change  |
boolean  |
query  |
False  |
Filter by filters.setattr_with_sacl_change  |
filters.setattr_with_size_change  |
boolean  |
query  |
False  |
Filter by filters.setattr_with_size_change  |
filters.setattr_with_allocation_size_change  |
boolean  |
query  |
False  |
Filter by filters.setattr_with_allocation_size_change  |
filters.setattr_with_modify_time_change  |
boolean  |
query  |
False  |
Filter by filters.setattr_with_modify_time_change  |
filters.write_with_size_change  |
boolean  |
query  |
False  |
Filter by filters.write_with_size_change  |
filters.setattr_with_mode_change  |
boolean  |
query  |
False  |
Filter by filters.setattr_with_mode_change  |
filters.monitor_ads  |
boolean  |
query  |
False  |
Filter by filters.monitor_ads  |
filters.close_with_modification  |
boolean  |
query  |
False  |
Filter by filters.close_with_modification  |
filters.first_read  |
boolean  |
query  |
False  |
Filter by filters.first_read  |
filters.setattr_with_owner_change  |
boolean  |
query  |
False  |
Filter by filters.setattr_with_owner_change  |
filters.first_write  |
boolean  |
query  |
False  |
Filter by filters.first_write  |
filters.setattr_with_creation_time_change  |
boolean  |
query  |
False  |
Filter by filters.setattr_with_creation_time_change  |
filters.setattr_with_dacl_change  |
boolean  |
query  |
False  |
Filter by filters.setattr_with_dacl_change  |
filters.exclude_directory  |
boolean  |
query  |
False  |
Filter by filters.exclude_directory  |
filters.offline_bit  |
boolean  |
query  |
False  |
Filter by filters.offline_bit  |
filters.open_with_write_intent  |
boolean  |
query  |
False  |
Filter by filters.open_with_write_intent  |
filters.setattr_with_group_change  |
boolean  |
query  |
False  |
Filter by filters.setattr_with_group_change  |
filters.close_without_modification  |
boolean  |
query  |
False  |
Filter by filters.close_without_modification  |
filters.close_with_read  |
boolean  |
query  |
False  |
Filter by filters.close_with_read  |
filters.open_with_delete_intent  |
boolean  |
query  |
False  |
Filter by filters.open_with_delete_intent  |
name  |
string  |
query  |
False  |
Filter by name  |
svm.uuid  |
string  |
path  |
True  |
UUID of the SVM to which this object belongs.  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
max_records  |
integer  |
query  |
False  |
Limit the number of records returned.  |
return_records  |
boolean  |
query  |
False  |
return_timeout  |
integer  |
query  |
False  |
order_by  |
array[string]  |
query  |
False  |
Order results by specified fields and optional [asc  |
Status: 200, Ok
| Name | Type | Description |
_links  |
num_records  |
integer  |
Number of records  |
records  |
array[fpolicy_event]  |
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "name": "event_nfs_close",
      "protocol": "string"
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
next  |
self  |
file_operations
Specifies the file operations for the FPolicy event. You must specify a valid protocol in the protocol parameter. The event will check the operations specified from all client requests using the protocol.
close  |
boolean  |
File close operations  |
create  |
boolean  |
File create operations  |
create_dir  |
boolean  |
Directory create operations  |
delete  |
boolean  |
File delete operations  |
delete_dir  |
boolean  |
Directory delete operations  |
getattr  |
boolean  |
Get attribute operations  |
link  |
boolean  |
Link operations  |
lookup  |
boolean  |
Lookup operations  |
open  |
boolean  |
File open operations  |
read  |
boolean  |
File read operations  |
rename  |
boolean  |
File rename operations  |
rename_dir  |
boolean  |
Directory rename operations  |
setattr  |
boolean  |
Set attribute operations  |
symlink  |
boolean  |
Symbolic link operations  |
write  |
boolean  |
File write operations  |
filters
Specifies the list of filters for a given file operation for the specified protocol. When you specify the filters, you must specify the valid protocols and a valid file operations.
boolean  |
Filter the client request for close with modification.  |
close_with_read  |
boolean  |
Filter the client request for close with read.  |
boolean  |
Filter the client request for close without modification.  |
exclude_directory  |
boolean  |
Filter the client requests for directory operations. When this filter is specified directory operations are not monitored.  |
first_read  |
boolean  |
Filter the client requests for the first-read.  |
first_write  |
boolean  |
Filter the client requests for the first-write.  |
monitor_ads  |
boolean  |
Filter the client request for alternate data stream.  |
offline_bit  |
boolean  |
Filter the client request for offline bit set. FPolicy server receives notification only when offline files are accessed.  |
boolean  |
Filter the client request for open with delete intent.  |
boolean  |
Filter the client request for open with write intent.  |
boolean  |
Filter the client setattr requests for changing the access time of a file or directory.  |
boolean  |
Filter the client setattr requests for changing the allocation size of a file.  |
boolean  |
Filter the client setattr requests for changing the creation time of a file or directory.  |
boolean  |
Filter the client setattr requests for changing dacl on a file or directory.  |
boolean  |
Filter the client setattr requests for changing group of a file or directory.  |
boolean  |
Filter the client setattr requests for changing the mode bits on a file or directory.  |
boolean  |
Filter the client setattr requests for changing the modification time of a file or directory.  |
boolean  |
Filter the client setattr requests for changing owner of a file or directory.  |
boolean  |
Filter the client setattr requests for changing sacl on a file or directory.  |
boolean  |
Filter the client setattr requests for changing the size of a file.  |
boolean  |
Filter the client request for write with size change.  |
fpolicy_event
The information that a FPolicy process needs to determine what file access operations to monitor and for which of the monitored events notifications should be sent to the external FPolicy server.
file_operations  |
Specifies the file operations for the FPolicy event. You must specify a valid protocol in the protocol parameter. The event will check the operations specified from all client requests using the protocol.  |
filters  |
Specifies the list of filters for a given file operation for the specified protocol. When you specify the filters, you must specify the valid protocols and a valid file operations.  |
name  |
string  |
Specifies the name of the FPolicy event.  |
protocol  |
string  |
Protocol for which event is created. If you specify protocol, then you must also specify a valid value for the file operation parameters. The value of this parameter must be one of the following:
volume_monitoring  |
boolean  |
Specifies whether volume operation monitoring is required.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
