REST API reference
Retrieve the FPolicy event configuration for all events for an SVM
Retrieves the FPolicy event configurations for all events associated with a specified SVM. This helps you understand the template of cluster-level FPolicy events applicable to the data SVMs within the cluster.
HTTP method and endpoint
GET /protocols/fpolicy/{svm.uuid}/events
Introduced in
ONTAP 9.6
Usage notes
Retrieves FPolicy event configurations for all events for a specified SVM. ONTAP allows the creation of cluster-level FPolicy events that act as a template for all the data SVMs belonging to the cluster. These cluster-level FPolicy events are also retrieved for the specified SVM.
  • fpolicy policy event show
volume_monitoring
boolean
query
False
Filter by volume_monitoring
monitor_fileop_failure
boolean
query
False
Filter by monitor_fileop_failure
  • Introduced in: 9.13
filters.first_write
boolean
query
False
Filter by filters.first_write
filters.open_with_write_intent
boolean
query
False
Filter by filters.open_with_write_intent
filters.setattr_with_allocation_size_change
boolean
query
False
Filter by filters.setattr_with_allocation_size_change
filters.first_read
boolean
query
False
Filter by filters.first_read
filters.setattr_with_access_time_change
boolean
query
False
Filter by filters.setattr_with_access_time_change
filters.setattr_with_creation_time_change
boolean
query
False
Filter by filters.setattr_with_creation_time_change
filters.offline_bit
boolean
query
False
Filter by filters.offline_bit
filters.close_with_modification
boolean
query
False
Filter by filters.close_with_modification
filters.setattr_with_size_change
boolean
query
False
Filter by filters.setattr_with_size_change
filters.setattr_with_group_change
boolean
query
False
Filter by filters.setattr_with_group_change
filters.setattr_with_dacl_change
boolean
query
False
Filter by filters.setattr_with_dacl_change
filters.close_without_modification
boolean
query
False
Filter by filters.close_without_modification
filters.open_with_delete_intent
boolean
query
False
Filter by filters.open_with_delete_intent
filters.monitor_ads
boolean
query
False
Filter by filters.monitor_ads
filters.setattr_with_owner_change
boolean
query
False
Filter by filters.setattr_with_owner_change
filters.write_with_size_change
boolean
query
False
Filter by filters.write_with_size_change
filters.setattr_with_sacl_change
boolean
query
False
Filter by filters.setattr_with_sacl_change
filters.exclude_directory
boolean
query
False
Filter by filters.exclude_directory
filters.close_with_read
boolean
query
False
Filter by filters.close_with_read
filters.setattr_with_modify_time_change
boolean
query
False
Filter by filters.setattr_with_modify_time_change
filters.setattr_with_mode_change
boolean
query
False
Filter by filters.setattr_with_mode_change
name
string
query
False
Filter by name
file_operations.create_dir
boolean
query
False
Filter by file_operations.create_dir
file_operations.delete
boolean
query
False
Filter by file_operations.delete
boolean
query
False
file_operations.rename
boolean
query
False
Filter by file_operations.rename
file_operations.access
boolean
query
False
Filter by file_operations.access
file_operations.delete_dir
boolean
query
False
Filter by file_operations.delete_dir
file_operations.rename_dir
boolean
query
False
Filter by file_operations.rename_dir
file_operations.close
boolean
query
False
Filter by file_operations.close
file_operations.getattr
boolean
query
False
Filter by file_operations.getattr
file_operations.write
boolean
query
False
Filter by file_operations.write
file_operations.read
boolean
query
False
Filter by file_operations.read
file_operations.link
boolean
query
False
Filter by file_operations.link
file_operations.setattr
boolean
query
False
Filter by file_operations.setattr
file_operations.lookup
boolean
query
False
Filter by file_operations.lookup
file_operations.symlink
boolean
query
False
Filter by file_operations.symlink
file_operations.open
boolean
query
False
Filter by file_operations.open
protocol
string
query
False
Filter by protocol
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[fpolicy_event]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "name": "event_cifs",
      "protocol": "string",
      "svm": {
        "uuid": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
file_operations
Specifies the file operations for the FPolicy event. You must specify a valid protocol in the protocol parameter. The event will check the operations specified from all client requests using the protocol.
access
boolean
Access operations
close
boolean
File close operations
create
boolean
File create operations
create_dir
boolean
Directory create operations
delete
boolean
File delete operations
delete_dir
boolean
Directory delete operations
getattr
boolean
Get attribute operations
link
boolean
Link operations
lookup
boolean
Lookup operations
open
boolean
File open operations
read
boolean
File read operations
rename
boolean
File rename operations
rename_dir
boolean
Directory rename operations
setattr
boolean
Set attribute operations
symlink
boolean
Symbolic link operations
write
boolean
File write operations
filters
Specifies the list of filters for a given file operation for the specified protocol. When you specify the filters, you must specify the valid protocols and a valid file operations.
boolean
Filter the client request for close with modification.
close_with_read
boolean
Filter the client request for close with read.
boolean
Filter the client request for close without modification.
exclude_directory
boolean
Filter the client requests for directory operations. When this filter is specified directory operations are not monitored.
first_read
boolean
Filter the client requests for the first-read.
first_write
boolean
Filter the client requests for the first-write.
monitor_ads
boolean
Filter the client request for alternate data stream.
offline_bit
boolean
Filter the client request for offline bit set. FPolicy server receives notification only when offline files are accessed.
boolean
Filter the client request for open with delete intent.
boolean
Filter the client request for open with write intent.
boolean
Filter the client setattr requests for changing the access time of a file or directory.
boolean
Filter the client setattr requests for changing the allocation size of a file.
boolean
Filter the client setattr requests for changing the creation time of a file or directory.
boolean
Filter the client setattr requests for changing dacl on a file or directory.
boolean
Filter the client setattr requests for changing group of a file or directory.
boolean
Filter the client setattr requests for changing the mode bits on a file or directory.
boolean
Filter the client setattr requests for changing the modification time of a file or directory.
boolean
Filter the client setattr requests for changing owner of a file or directory.
boolean
Filter the client setattr requests for changing sacl on a file or directory.
boolean
Filter the client setattr requests for changing the size of a file.
boolean
Filter the client request for write with size change.
svm
uuid
string
SVM UUID
fpolicy_event
The information that a FPolicy process needs to determine what file access operations to monitor and for which of the monitored events notifications should be sent to the external FPolicy server.
file_operations
file_operations
filters
filters
boolean
Specifies whether failed file operations monitoring is required.
name
string
Specifies the name of the FPolicy event.
protocol
string
Protocol for which event is created. If you specify protocol, then you must also specify a valid value for the file operation parameters. The value of this parameter must be one of the following:
  • cifs - for the CIFS protocol.
  • nfsv3 - for the NFSv3 protocol.
  • nfsv4 - for the NFSv4 protocol.
svm
svm
volume_monitoring
boolean
Specifies whether volume operation monitoring is required.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
