Retrieve NVMe subsystem controllers
Retrieves NVMe subsystem controllers to access configuration and status information for NVMe protocol usage. This helps in managing and monitoring NVMe storage resources effectively.
HTTP method and endpoint
GET /protocols/nvme/subsystem-controllers
Introduced in
ONTAP 9.6
Related ONTAP commands
vserver nvme subsystem controller show
Learn more
id |
string |
query |
False |
Filter by id |
interface.name |
string |
query |
False |
Filter by interface.name |
interface.uuid |
string |
query |
False |
Filter by interface.uuid |
interface.transport_address |
string |
query |
False |
Filter by interface.transport_address |
subsystem.name |
string |
query |
False |
Filter by subsystem.name |
subsystem.uuid |
string |
query |
False |
Filter by subsystem.uuid |
admin_queue.depth |
integer |
query |
False |
Filter by admin_queue.depth |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
node.name |
string |
query |
False |
Filter by node.name |
node.uuid |
string |
query |
False |
Filter by node.uuid |
io_queue.count |
integer |
query |
False |
Filter by io_queue.count |
io_queue.depth |
integer |
query |
False |
Filter by io_queue.depth |
host.nqn |
string |
query |
False |
Filter by host.nqn |
host.id |
string |
query |
False |
Filter by host.id |
host.transport_address |
string |
query |
False |
Filter by host.transport_address |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records. |
records |
array[nvme_subsystem_controller] |
"next": {
"href": "/api/resourcelink"
"records": [
"admin_queue": {
"depth": 0
"host": {
"id": "b8546ca6097349e5b1558dc154fc073b",
"nqn": "nqn.2014-08.org.nvmexpress:uuid:c2846cb1-89d2-4020-a3b0-71ce907b4eef",
"transport_address": "nn-0x20000090fae00806:pn-0x10000090fae00806"
"id": "0040h",
"interface": {
"name": "lif1",
"transport_address": "nn-0x200400a0989a1c8d:pn-0x200500a0989a1c8d",
"uuid": "fa1c5941-2593-11e9-94c4-00a0989a1c8e"
"io_queue": {
"count": 0,
"depth": [
"integer"
"node": {
"name": "node1",
"subsystem": {
"name": "string",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
admin_queue
depth |
integer |
The depth of the admin queue for the controller. |
host
Properties of the connected host.
id |
string |
The host identifier registered with the controller. |
nqn |
string |
The NVMe qualified name of the host. |
transport_address |
string |
The transport address of the host. |
interface
The logical interface through which the host is connected.
name |
string |
The name of the logical interface. |
transport_address |
string |
The transport address of the logical interface. |
uuid |
string |
The unique identifier of the logical interface. |
io_queue
Properties of the I/O queues available to the controller.
count |
integer |
The number of I/O queues available to the controller. |
depth |
array[integer] |
The depths of the I/O queues. |
node
_links |
name |
string |
uuid |
string |
subsystem
_links |
name |
string |
The name of the NVMe subsystem. |
uuid |
string |
The unique identifier of the NVMe subsystem. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
A Non-Volatile Memory Express (NVMe) subsystem controller represents a connection between a host and a storage solution.
An NVMe subsystem controller is identified by the NVMe subsystem UUID and the controller ID.
_links |
admin_queue |
host |
Properties of the connected host. |
id |
string |
The identifier of the subsystem controller. This field consists of 4 zero-filled hexadecimal digits followed by an 'h'. |
interface |
The logical interface through which the host is connected. |
io_queue |
Properties of the I/O queues available to the controller. |
node |
subsystem |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
