REST API reference
Retrieve NVMe subsystem controllers
Retrieves NVMe subsystem controllers, detailing the controllers associated with NVMe subsystems. This helps you manage and monitor NVMe storage configurations in your environment.
HTTP method and endpoint
GET /protocols/nvme/subsystem-controllers
Introduced in
ONTAP 9.6
  • vserver nvme subsystem controller show
id
string
query
False
Filter by id
host.id
string
query
False
Filter by host.id
host.nqn
string
query
False
Filter by host.nqn
  • maxLength: 223
  • minLength: 1
host.transport_address
string
query
False
Filter by host.transport_address
interface.transport_address
string
query
False
Filter by interface.transport_address
interface.uuid
string
query
False
Filter by interface.uuid
interface.name
string
query
False
Filter by interface.name
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
subsystem.uuid
string
query
False
Filter by subsystem.uuid
subsystem.name
string
query
False
Filter by subsystem.name
  • maxLength: 64
  • minLength: 1
node.name
string
query
False
Filter by node.name
node.uuid
string
query
False
Filter by node.uuid
admin_queue.depth
integer
query
False
Filter by admin_queue.depth
dh_hmac_chap.mode
string
query
False
Filter by dh_hmac_chap.mode
  • Introduced in: 9.12
dh_hmac_chap.group_size
string
query
False
Filter by dh_hmac_chap.group_size
dh_hmac_chap.hash_function
string
query
False
Filter by dh_hmac_chap.hash_function
io_queue.depth
integer
query
False
Filter by io_queue.depth
io_queue.count
integer
query
False
Filter by io_queue.count
keep_alive_timeout
integer
query
False
Filter by keep_alive_timeout
  • Introduced in: 9.14
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
The number of records in the response.
records
array[nvme_subsystem_controller]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "admin_queue": {
        "depth": 0
      "dh_hmac_chap": {
        "group_size": "string",
        "hash_function": "string",
        "mode": "bidirectional"
      "host": {
        "id": "b8546ca6097349e5b1558dc154fc073b",
        "nqn": "nqn.2014-08.org.nvmexpress:uuid:c2846cb1-89d2-4020-a3b0-71ce907b4eef",
        "transport_address": "nn-0x20000090fae00806:pn-0x10000090fae00806"
      "id": "0040h",
      "interface": {
        "name": "lif1",
        "transport_address": "nn-0x200400a0989a1c8d:pn-0x200500a0989a1c8d",
        "uuid": "fa1c5941-2593-11e9-94c4-00a0989a1c8e"
      "io_queue": {
        "count": 0,
        "depth": [
          "integer"
      "keep_alive_timeout": 1500,
      "node": {
        "name": "node1",
      "subsystem": {
        "name": "subsystem1",
      "svm": {
        "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
admin_queue
depth
integer
The depth of the admin queue for the controller.
dh_hmac_chap
A container for properties of the NVMe in-band authentication DH-HMAC-CHAP protocol used by the the host connection to the controller.
group_size
string
The Diffie-Hellman group size used for NVMe in-band authentication.
hash_function
string
The hash function used for NVMe in-band authentication.
mode
string
The NVMe in-band authentication mode used for the host connection. When set to:
  • none: Neither the host nor controller was authenticated.
  • unidirectional: The controller authenticated the host.
  • bidirectional: The controller authenticated the host and the host authenticated the controller.
host
Properties of the connected host.
id
string
The host identifier registered with the controller.
nqn
string
The NVMe qualified name of the host.
transport_address
string
The transport address of the host.
interface
The logical interface through which the host is connected.
name
string
The name of the logical interface.
transport_address
string
The transport address of the logical interface.
uuid
string
The unique identifier of the logical interface.
io_queue
Properties of the I/O queues available to the controller.
count
integer
The number of I/O queues available to the controller.
depth
array[integer]
The depths of the I/O queues.
node
_links
_links
name
string
uuid
string
subsystem
An NVMe subsystem maintains configuration state and NVMe namespace access control for a set of NVMe-connected hosts.
_links
_links
name
string
The name of the NVMe subsystem.
uuid
string
The unique identifier of the NVMe subsystem.
svm
_links
_links
name
string
uuid
string
A Non-Volatile Memory Express (NVMe) subsystem controller represents a connection between a host and a storage solution.
An NVMe subsystem controller is identified by the NVMe subsystem UUID and the controller ID.
_links
_links
admin_queue
admin_queue
dh_hmac_chap
dh_hmac_chap
host
host
id
string
The identifier of the subsystem controller. This field consists of 4 zero-filled hexadecimal digits followed by an 'h'.
interface
interface
io_queue
io_queue
keep_alive_timeout
integer
The keep-alive timeout value for the controller and all of its host connections, in milliseconds.
If the NVMe controller does not receive a keep-alive request or an I/O request within the timeout window, the NVMe controller terminates its admin queue and I/O queue connections leading to NVMe controller teardown. If the NVMe host does not receive a response to a keep-alive request or an I/O request within the timeout window, the NVMe host initiates a connection disconnect.
node
node
subsystem
subsystem
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
