Create a SnapLock log configuration for an SVM
Creates a SnapLock log configuration for an SVM, specifying details like the log volume, maximum log file size, and retention period. This configuration helps manage and retain audit logs according to your compliance needs.
HTTP method and endpoint
POST /storage/snaplock/audit-logs
Introduced in
ONTAP 9.7
Usage notes
A SnapLock log configuration consists of a volume to store the log, the maximum size of the log file, and the default period of time for which the log file should be retained. The input parameter retention_period expects the duration in ISO 8601 format.
Required properties
svm.uuidorsvm.name- Name or UUID of the SVM. -
log_volume.volume.nameorlog_volume.volume.uuid- Name or UUID of audit log volume.
Recommended optional properties
log_volume.max_log_size- Max log file size. -
log_volume.volume.retention_period- Retention period of log file.
Default property values
If not specified in POST, the following default property values are assigned:
log_volume.retention_period- P6M -
log_volume.max_log_size- 10MB
Related ONTAP commands
snaplock log create
Learn more
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
log_archive |
log_files |
array[snaplock_log_file] |
log_volume |
svm |
Example request
"log_archive": {
"base_name": "string",
"expiry_time": "2058-06-04T19:00:00Z",
"path": "/snaplock_log/system_logs/20180822_005947_GMT-present",
"size": "20000"
"log_files": [
"size": "20000"
"log_volume": {
"max_log_size": "20971520",
"retention_period": "P30M",
"volume": {
"name": "volume1",
"svm": {
"name": "svm1",
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response codes
| Error code | Description |
14090340 |
{field} is a required field |
14090343 |
Invalid Field |
14090346 |
Internal Error. Wait a few minutes, then try the command again |
href |
string |
_links
log_archive
archive |
boolean |
Archive the specified SnapLock log file for the given base_name, and create a new log file. If base_name is not mentioned, archive all log files. |
base_name |
string |
Base name of log file |
expiry_time |
string |
Expiry time of the log file in date-time format. Value '9999-12-31T00:00:00Z' indicates infinite expiry time. |
path |
string |
Absolute path of the log file in the volume |
size |
integer |
Size of the log file in bytes |
snaplock_log_file
archive |
boolean |
base_name |
string |
expiry_time |
string |
path |
string |
size |
integer |
volume
name |
string |
The name of the volume. |
uuid |
string |
snaplock_log_volume
max_log_size |
integer |
Maximum size of log file in bytes |
retention_period |
string |
Specifies the default log record retention period. The retention period value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours, minutes and seconds. A period specified for years, months and days is represented in the ISO-8601 format as "P |
volume |
svm
name |
string |
The name of the SVM. |
uuid |
string |
snaplock_log
log_archive |
log_files |
log_volume |
svm |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
