REST API reference
Create a SnapLock log configuration for an SVM
Creates a SnapLock log configuration for a Storage Virtual Machine (SVM) to specify where and how long audit logs are stored. This configuration helps manage compliance and data retention by defining a SnapLock volume for logs, the maximum file size, and the retention period.
HTTP method and endpoint
POST /storage/snaplock/audit-logs
Introduced in
ONTAP 9.7
Usage notes
Creates a SnapLock log configuration for an SVM. A SnapLock log configuration consists of a volume to store the log, the maximum size of the log file, and the default period of time for which the log file should be retained. The volume must be a Read-Write SnapLock volume of type Enterprise or Compliance. The input parameter retention_period expects the duration in ISO 8601 format.
Required properties
  • svm.uuid or svm.name - Name or UUID of the SVM.
  • log_volume.volume.name or log_volume.volume.uuid - Name or UUID of audit log volume.
  • log_volume.max_log_size - Max log file size.
  • log_volume.volume.retention_period - Retention period of log file.
Default property values
If not specified in POST, the following default property values are assigned:
  • log_volume.retention_period - P6M
  • log_volume.max_log_size - 10MB
  • snaplock log create
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
log_files
array[snaplock_log_file]
log_volume
snaplock_log_volume
svm
svm
Example request
  "log_files": [
      "base_name": "string",
      "expiry_time": "2058-06-04 15:00:00 -0400",
      "path": "/snaplock_log/system_logs/20180822_005947_GMT-present",
      "size": 20000
  "log_volume": {
    "max_log_size": 20971520,
    "retention_period": "P30M",
    "volume": {
      "name": "volume1",
  "svm": {
    "name": "svm1",
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: 201, Created
Status: Default
ONTAP Error Response codes
Error code Description
918236
The specified volume name and UUID refer to different volumes
918253
Incorrect format for the retention period, duration must be in the ISO-8601 format
13763161
Audit logging is already configured for the SVM
14090340
{field} is a required field
14090343
Invalid Field
14090346
Internal Error. Wait a few minutes, then try the command again
string
log_archive
archive
boolean
Archive the specified SnapLock log file for the given base_name, and create a new log file. If base_name is not mentioned, archive all log files.
base_name
string
Base name of log archive
snaplock_log_file
base_name
string
Base name of log file
expiry_time
string
Expiry time of the log file in date-time format. Value '9999-12-31T00:00:00Z' indicates infinite expiry time.
path
string
Absolute path of the log file in the volume
size
integer
Size of the log file in bytes
volume
name
string
The name of the volume. This field cannot be specified in a POST or PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
snaplock_log_volume
max_log_size
integer
Maximum size of log file in bytes
retention_period
string
Specifies the default log record retention period. The retention period value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours, minutes and seconds. A period specified for years, months and days is represented in the ISO-8601 format as "PY", "PM", "PD" respectively. For example "P10Y" represents a duration of 10 years. A duration in hours, minutes and seconds is represented by "PTH", "PTM", and "PTS" respectively. The period string must contain only a single time element i.e. either years, months, days, hours, minutes or seconds. A duration which combines different periods is not supported, example "P1Y10M" is not supported. Apart from the duration specified in the ISO-8601 format, the retention period field also accepts the string "infinite".
volume
volume
svm
name
string
uuid
string
snaplock_log
log_files
log_volume
snaplock_log_volume
svm
svm
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
