Create a SnapLock log configuration for an SVM
Creates a SnapLock log configuration for a Storage Virtual Machine (SVM) to specify where and how long audit logs are stored. This configuration helps manage compliance and data retention by defining a SnapLock volume for logs, the maximum file size, and the retention period.
HTTP method and endpoint
POST /storage/snaplock/audit-logs
Introduced in
ONTAP 9.7
Usage notes
Creates a SnapLock log configuration for an SVM. A SnapLock log configuration consists of a volume to store the log, the maximum size of the log file, and the default period of time for which the log file should be retained. The volume must be a Read-Write SnapLock volume of type Enterprise or Compliance. The input parameter retention_period expects the duration in ISO 8601 format.
Required properties
svm.uuidorsvm.name- Name or UUID of the SVM. -
log_volume.volume.nameorlog_volume.volume.uuid- Name or UUID of audit log volume.
Recommended optional properties
log_volume.max_log_size- Max log file size. -
log_volume.volume.retention_period- Retention period of log file.
Default property values
If not specified in POST, the following default property values are assigned:
log_volume.retention_period- P6M -
log_volume.max_log_size- 10MB
Related ONTAP commands
snaplock log create
Learn more
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
log_files |
array[snaplock_log_file] |
log_volume |
svm |
Example request
"log_files": [
"base_name": "string",
"expiry_time": "2058-06-04 19:00:00 +0000",
"path": "/snaplock_log/system_logs/20180822_005947_GMT-present",
"size": 20000
"log_volume": {
"max_log_size": 20971520,
"retention_period": "P30M",
"volume": {
"name": "volume1",
"svm": {
"name": "svm1",
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: 201, Created
Status: Default
ONTAP Error Response codes
| Error code | Description |
918236 |
The specified volume name and UUID refer to different volumes |
918253 |
Incorrect format for the retention period, duration must be in the ISO-8601 format |
13763161 |
Audit logging is already configured for the SVM |
14090340 |
{field} is a required field |
14090343 |
Invalid Field |
14090346 |
Internal Error. Wait a few minutes, then try the command again |
href |
string |
_links
log_archive
archive |
boolean |
Archive the specified SnapLock log file for the given base_name, and create a new log file. If base_name is not mentioned, archive all log files. |
base_name |
string |
Base name of log archive |
snaplock_log_file
base_name |
string |
Base name of log file |
expiry_time |
string |
Expiry time of the log file in date-time format. Value '9999-12-31T00:00:00Z' indicates infinite expiry time. |
path |
string |
Absolute path of the log file in the volume |
size |
integer |
Size of the log file in bytes |
volume
name |
string |
The name of the volume. This field cannot be specified in a PATCH method. |
uuid |
string |
snaplock_log_volume
max_log_size |
integer |
Maximum size of log file in bytes |
retention_period |
string |
Specifies the default log record retention period. The retention period value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours, minutes and seconds. A period specified for years, months and days is represented in the ISO-8601 format as "P |
volume |
svm
name |
string |
uuid |
string |
snaplock_log
log_files |
log_volume |
svm |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
