Add a schedule to a Snapshot copy policy
Adds a schedule to a Snapshot copy policy to define when Snapshot copies are captured on the volume. This helps manage and automate the creation of backups according to your specified schedule.
HTTP method and endpoint
POST /storage/snapshot-policies/{snapshot_policy.uuid}/schedules
Introduced in
ONTAP 9.8
Required properties
schedule.uuidorschedule.name- Schedule at which Snapshot copies are captured on the volume. -
count- Number of Snapshot copies to maintain for this schedule.
Recommended optional properties
prefix- Prefix to use when creating Snapshot copies at regular intervals.
Default property values
If not specified in POST, the following default property values are assigned:
prefix- Value ofschedule.name
Related ONTAP commands
snapshot policy add-schedule
snapshot_policy.uuid |
string |
path |
True |
Snapshot copy policy UUID |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
count |
integer |
The number of Snapshot copies to maintain for this schedule. |
prefix |
string |
The prefix to use while creating Snapshot copies at regular intervals. |
schedule |
snapmirror_label |
string |
Label for SnapMirror operations |
snapshot_policy |
This is a reference to the Snapshot copy policy. |
Example request
"prefix": "string",
"schedule": {
"name": "weekly",
"snapmirror_label": "string",
"snapshot_policy": {
"name": "default",
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1638407 |
When adding schedule to a Snapshot copy policy, the count for that schedule must be specified. |
1638410 |
Specified schedule already exists in snapshot policy. |
1638413 |
Schedule not found. |
1638451 |
This operation would result in total Snapshot copy count for the policy to exceed maximum supported count. |
1638508 |
Another schedule has the same prefix within this policy. |
1638528 |
This operation is not supported in a mixed-version cluster. |
1638531 |
This operation is not supported because specified policy is owned by the cluster admin. |
href |
string |
_links
schedule
name |
string |
Job schedule name |
uuid |
string |
Job schedule UUID |
snapshot_policy
name |
string |
uuid |
string |
snapshot_policy_schedule
The Snapshot copy policy schedule object is associated with a Snapshot copy policy and it defines the interval at which Snapshot copies are created and deleted.
count |
integer |
prefix |
string |
schedule |
snapmirror_label |
string |
snapshot_policy |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
