Add a schedule to a snapshot policy
POST /storage/snapshot-policies/{snapshot_policy.uuid}/schedules
Introduced In: 9.8
Adds a schedule to a snapshot policy.
Required properties
schedule.uuidorschedule.name- Schedule at which snapshots are captured on the volume. -
count- Number of snapshots to maintain for this schedule.
Recommended optional properties
prefix- Prefix to use when creating snapshots at regular intervals.
Default property values
If not specified in POST, the following default property values are assigned:
prefix- Value ofschedule.name
Related ONTAP commands
snapshot policy add-schedule
snapshot_policy.uuid  |
string  |
path  |
True  |
Snapshot policy UUID  |
return_records  |
boolean  |
query  |
False  |
Request Body
| Name | Type | Description |
count  |
integer  |
The number of snapshots to maintain for this schedule.  |
prefix  |
string  |
The prefix to use while creating snapshots at regular intervals.  |
retention_period  |
string  |
The retention period of snapshots for this schedule.  |
schedule  |
snapmirror_label  |
string  |
Label for SnapMirror operations  |
snapshot_policy  |
This is a reference to the snapshot policy.  |
Example request
  "prefix": "string",
  "retention_period": "string",
  "schedule": {
    "name": "weekly",
  "snapmirror_label": "string",
  "snapshot_policy": {
    "name": "default",
Status: 201, Created
Headers
| Name | Description | Type |
Location  |
Useful for tracking the resource location  |
string  |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1638407  |
When adding schedule to a snapshot policy, the count for that schedule must be specified.  |
1638410  |
Specified schedule already exists in snapshot policy.  |
1638413  |
Schedule not found.  |
1638451  |
This operation would result in total snapshot count for the policy to exceed maximum supported count.  |
1638508  |
Another schedule has the same prefix within this policy.  |
1638510  |
Duplicate prefix.  |
1638528  |
This operation is not supported in a mixed-version cluster.  |
1638531  |
This operation is not supported because specified policy is owned by the cluster admin.  |
918253  |
Incorrect format for the retention period, duration must be in the ISO-8601 format.  |
href  |
string  |
_links
schedule
name  |
string  |
Job schedule name  |
uuid  |
string  |
Job schedule UUID  |
snapshot_policy
name  |
string  |
uuid  |
string  |
snapshot_policy_schedule
The snapshot policy schedule object is associated with a snapshot policy and it defines the interval at which snapshots are created and deleted.
count  |
integer  |
prefix  |
string  |
retention_period  |
string  |
schedule  |
snapmirror_label  |
string  |
snapshot_policy  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
