REST API reference
Add a schedule to a Snapshot copy policy
Adds a schedule to a Snapshot copy policy, defining when and how often Snapshot copies are created on a specific volume. This helps ensure that data protection and recovery processes are consistently maintained according to the desired schedule.
HTTP method and endpoint
POST /storage/snapshot-policies/{snapshot_policy.uuid}/schedules
Introduced in
ONTAP 9.8
Required properties
  • schedule.uuid or schedule.name - Schedule at which Snapshot copies are captured on the volume.
  • count - Number of Snapshot copies to maintain for this schedule.
  • prefix - Prefix to use when creating Snapshot copies at regular intervals.
Default property values
If not specified in POST, the following default property values are assigned:
  • prefix - Value of schedule.name
  • snapshot policy add-schedule
string
path
True
Snapshot copy policy UUID
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
count
integer
The number of Snapshot copies to maintain for this schedule.
prefix
string
The prefix to use while creating Snapshot copies at regular intervals.
retention_period
string
The retention period of Snapshot copies for this schedule.
schedule
schedule
snapmirror_label
string
Label for SnapMirror operations
snapshot_policy
snapshot_policy
This is a reference to the Snapshot copy policy.
Example request
  "prefix": "string",
  "retention_period": "string",
  "schedule": {
    "name": "weekly",
  "snapmirror_label": "string",
  "snapshot_policy": {
    "name": "default",
Status: 201, Created
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
1638407
When adding schedule to a Snapshot copy policy, the count for that schedule must be specified.
1638410
Specified schedule already exists in snapshot policy.
1638413
Schedule not found.
1638451
This operation would result in total Snapshot copy count for the policy to exceed maximum supported count.
1638508
Another schedule has the same prefix within this policy.
1638510
Duplicate prefix.
1638528
This operation is not supported in a mixed-version cluster.
1638531
This operation is not supported because specified policy is owned by the cluster admin.
918253
Incorrect format for the retention period, duration must be in the ISO-8601 format.
string
schedule
name
string
Job schedule name
uuid
string
Job schedule UUID
snapshot_policy
name
string
uuid
string
snapshot_policy_schedule
The Snapshot copy policy schedule object is associated with a Snapshot copy policy and it defines the interval at which Snapshot copies are created and deleted.
count
integer
prefix
string
retention_period
string
schedule
schedule
snapmirror_label
string
snapshot_policy
snapshot_policy
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
