REST API reference
Manage cluster mediators
Manage cluster mediators used in MetroCluster IP and SnapMirror active sync configurations. Use these endpoints to add, modify, retrieve, or remove mediators as part of your cluster setup.
Overview
You can use this API to add, modify or remove a mediator in a MetroCluster IP configuration or a SnapMirror active sync configuration. You can also use this API to get the status and details of the existing mediator. The GET operation returns the status of the mediator along with the mediator details. The DELETE operation removes the mediator. The POST operation adds the mediator. The PATCH operation modifies the local and remote proxy options. SnapMirror active sync supports two types of mediators:
  1. ONTAP Mediator: This is the traditional mediator used in SnapMirror active sync, and is hosted on-premises. It requires deployment at a third, neutral site.
  2. ONTAP cloud mediator: This mediator is hosted on the NetApp Console cloud server and is primarily designed for SnapMirror active sync. It eliminates the need for a third site and provides enhanced scalability and availability.
Adding a mediator
A mediator can be added by issuing a POST request on /cluster/mediators. Parameters are provided in the body of the POST request. The field connection_type is an optional parameter for adding a mediator to a MetroCluster IP configuration.
Required configuration fields (MetroCluster)
These fields are always required for any POST /cluster/mediators request.
  • ip_address - Specifies the IP address of the mediator.
  • user - Specifies a user name credential.
  • password - Specifies a password credential.
Required configuration fields (MetroCluster HTTPS mediator)
  • connection_type - Must be https_mediator. If connection_type is omitted from the POST body, ONTAP automatically defaults to iscsi_mediator.
Required configuration fields (SnapMirror active sync: ONTAP Mediator, ONTAP cloud mediator)
These fields are required for any POST /cluster/mediators request.
  • type - (defaults to "on-prem" if omitted) Specifies the type of mediator. For the ONTAP Mediator, the value of type has to be "on-prem". For the ONTAP cloud mediator, the value of type has to be "cloud".
  • peer_cluster.name - Specifies the name of the peer cluster.
  • ip_address - (only applicable to the ONTAP Mediator) Specifies the IP address of the mediator.
  • user - (only applicable to the ONTAP Mediator) Specifies the user name credential.
  • password - (only applicable to the ONTAP Mediator) Specifies a password credential.
  • ca_certificate - (optional if the certificate is already installed, only applicable to the ONTAP Mediator) Specifies the CA certificate for the ONTAP Mediator.
  • bluexp_org_id - (DEPRECATED) Specifies the BlueXP organization ID. This has been replaced by org_id. Support for this field will be removed in a future release.
  • org_id - (only applicable to the ONTAP cloud mediator) Specifies the NetApp Console organization ID.
  • service_account_client_id - (only applicable to the ONTAP cloud mediator) Specifies the client ID of the service account.
  • service_account_client_secret - (only applicable to the ONTAP cloud mediator) Specifies the client secret of the service account.
  • bluexp_account_token - (DEPRECATED) Specifies the BlueXP service account token. This field is mutually exclusive with the service_account_client_id and service_account_client_secret pair, meaning either the token or the client-id and client-secret pair is allowed. This has been replaced by account_token. Support for this field will be removed in a future release.
  • account_token - (only applicable to the ONTAP cloud mediator) Specifies the NetApp Console service account token. This field is mutually exclusive with the service_account_client_id and service_account_client_secret pair, meaning either the token or the client-id and client-secret pair is allowed.
  • use_http_proxy_local - (optional, defaults to false if omitted, only applicable for ONTAP cloud mediator) Specifies if a HTTP proxy should be used on the ONTAP cluster.
  • use_http_proxy_remote - (optional, defaults to false if omitted, only applicable for ONTAP cloud mediator) Specifies if a HTTP proxy should be used on the peer ONTAP cluster.
  • strict_cert_validation - (optional, defaults to false if omitted, only applicable for ONTAP cloud mediator) Specifies if strict validation of certificates is performed while making REST API calls to the ONTAP Cloud Mediator.
Polling the setup job
After a successful POST /cluster/mediators is issued, an HTTP status code of 202 (Accepted) is returned along with a job UUID and a link in the body of the response. The setup job continues asynchronously and can be monitored by using the job UUID and the /cluster/jobs API. The "message" field in the response of the GET /cluster/jobs/{uuid} request shows the current step in the job, and the "state" field shows the overall state of the job.
Deleting a mediator
A mediator can be deleted by issuing a DELETE to /cluster/mediators/{uuid}. Parameters are provided in the body of the DELETE request. There are no optional parameters for deleting a mediator in a MetroCluster IP configuration.
These fields are always required for any DELETE /cluster/mediators/{uuid} request.
No fields are required in the body of the DELETE /cluster/mediators/{uuid} request for a mediator in SnapMirror active sync configuration.
Polling the delete job
After a successful DELETE /cluster/mediators/{uuid} is issued, an HTTP status code of 202 (Accepted) is returned along with a job UUID and a link in the body of the response. The delete job continues asynchronously and can be monitored by using the job UUID and the /cluster/jobs API. The "message" field in the response of the GET /cluster/jobs/{uuid} request shows the current step in the job, and the "state" field shows the overall state of the job.
Modify a mediator
An ONTAP cloud mediator can be modified by issuing a PATCH to /cluster/mediators/{uuid}. Parameters are provided in the body of the PATCH request. Currently there are only 2 parameters which can be modified.
Fields which can be modified
These fields can be modified by any PATCH /cluster/mediators/{uuid} request.
  • use-http-proxy-local - Specifies if the local cluster should use http-proxy server while making REST API calls to mediator.
  • use-http-proxy-remote - Specifies if the remote cluster should use http-proxy while making REST API calls to mediator.
Polling the modify job
After a successful PATCH /cluster/mediators/{uuid} is issued, an HTTP status code of 202 (Accepted) is returned along with a link in the body of the response. The modify response can be monitored by using the /cluster/jobs API. The "message" field in the response of the GET /cluster/jobs/{uuid} request shows the current step in the job, and the "state" field shows the overall state of the job.
Setting up a mediator for a four-node MetroCluster and a SnapMirror active sync configuration
This example shows the POST body when setting up a mediator for a four-node MetroCluster IP configuration and a SnapMirror active sync configuration. For MetroCluster, the only prerequisite is that MetroCluster IP is configured.
# API
/api/cluster/mediators
POST body included from file (MetroCluster: iSCSI Mediator)
mediator_post_body.txt:
"ip_address": "1.1.1.1",
"user": "username",
"password": "password"
curl -X POST https://<mgmt-ip>/api/cluster/mediators -d "@mediator_post_body.txt"
POST body included from file (MetroCluster: HTTPS Mediator)
"user": "username",
"password": "password",
"connection_type": "https_mediator"
POST body included from file (SnapMirror active sync: ONTAP Mediator)
"peer_cluster.name": "C2_sti230-vsim-sr092w_cluster",
"ip_address": "172.18.48.61",
"user": "username",
POST body included from file (SnapMirror active sync: ONTAP cloud mediator)
"type": "cloud",
"org_id":"your-netapp-console-org-id",
"service_account_client_id":"your-account-client-id",
"service_account_client_secret":"your-account-client-secret",
"use_http_proxy_local":"true",
"use_http_proxy_remote":"true",
"strict_cert_validation":"true"
Inline POST body (MetroCluster: iSCSI Mediator)
curl -X POST https://<mgmt-ip>/api/cluster/mediators -H "Content-Type: application/hal+json" -d '{"ip_address": "1.1.1.1", "user": "username", "password": "password"}'
Inline POST body (MetroCluster: HTTPS Mediator)
curl -X POST https://<mgmt-ip>/api/cluster/mediators -H "Content-Type: application/hal+json" -d '{"ip_address": "1.1.1.1", "user": "username", "password": "password", "connection_type":"https_mediator" }'
Inline POST body (SnapMirror active sync: ONTAP Mediator)
curl -X POST https://<mgmt-ip>/api/cluster/mediators -H "Content-Type: application/hal+json" -d '{"peer_cluster.name": "C2_sti230-vsim-sr092w_cluster", "ip_address": "172.18.48.61", "user": "username", "password": "password"}'
Inline POST body (SnapMirror active sync: ONTAP cloud mediator)
curl -X POST https://<mgmt-ip>/api/cluster/mediators -H "Content-Type: application/hal+json" -d '{"peer_cluster.name": "C2_sti230-vsim-sr092w_cluster", "type": "cloud", "org_id": "your-netapp-console-org-id", "service_account_client_id": "your-account-client-id", "service_account_client_secret": "your-account-client-secret", "use_http_proxy_local": "true", "use_http_proxy_remote": "true", "strict_cert_validation": "true"}'
POST Response
HTTP/1.1 202 Accepted
Date: Tue, 22 Sep 2020 07:40:59 GMT
Server: libzapid-httpd
X-Content-Type-Options: nosniff
Cache-Control: no-cache,no-store,must-revalidate
Content-Length: 189
"job": {
  "uuid": "f567b48b-fca6-11ea-acaf-005056bb47c1",
      "href": "/api/cluster/jobs/f567b48b-fca6-11ea-acaf-005056bb47c1"
Monitoring the job progress
Use the link provided in the response to the POST request to fetch information for the mediator setup job.
Request
curl -X GET https://<mgmt-ip>/api/cluster/jobs/f567b48b-fca6-11ea-acaf-005056bb47c1
Job status response
Date: Tue, 22 Sep 2020 07:41:29 GMT
Content-Length: 189
"description": "POST /api/cluster/mediators/",
"state": "running",
"start_time": "2020-09-22T03:41:00-04:00",
Final status of a successful Mediator add
Date: Tue, 22 Sep 2020 07:43:38 GMT
Content-Length: 358
"state": "success",
"message": "success",
"code": 0,
"end_time": "2020-09-22T03:42:10-04:00",
Retrieving the existing mediator configurations
Request
curl -X GET https://<mgmt-ip>/api/cluster/mediators
Date: Tue, 22 Sep 2020 08:53:18 GMT
Content-Length: 320
"records": [
    "uuid": "f89e8906-fca6-11ea-acaf-005056bb47c1",
        "href": "/api/cluster/mediators/f89e8906-fca6-11ea-acaf-005056bb47c1"
"num_records": 1,
    "href": "/api/cluster/mediators"
Retrieving a specific mediator using the UUID
Request
curl -X GET https://<mgmt-ip>/api/cluster/mediators/f89e8906-fca6-11ea-acaf-005056bb47c1
Response (MetroCluster)
Date: Tue, 22 Sep 2020 08:59:40 GMT
Content-Length: 347
"ip_address": "10.234.173.40",
"port": 31784,
"reachable": true,
"peer_cluster": {
  "name": "mcc_siteB",
  "uuid": "38779fd1-fc6b-11ea-9421-005056bb21d8"
"peer_mediator_connectivity": "connected",
"strict_cert_validation": "true",
Response (SnapMirror active sync: ONTAP Mediator)
"uuid": "cc44f61f-ffd5-11ef-aaa6-005056ae32ff",
"port": 31784,
"reachable": true,
"peer_cluster": {
  "name": "C2_sti232-vsim-sr089o_cluster",
  "uuid": "ece8d7c6-fd8f-11ef-b8b3-005056aec21e"
"local_mediator_connectivity": "connected",
"type": "on_prem",
    "href": "/api/cluster/mediators/cc44f61f-ffd5-11ef-aaa6-005056ae32ff"
Response (SnapMirror active sync: ONTAP cloud mediator)
"uuid": "b9ba4e5b-ff14-11ef-82a4-005056ae1bc8",
"ip_address": "0.0.0.0",
"reachable": true,
"peer_cluster": {
"use_http_proxy_local": true,
"use_http_proxy_remote": true,
"type": "cloud",
    "href": "/api/cluster/mediators/b9ba4e5b-ff14-11ef-82a4-005056ae1bc8"
Deleting a configured mediator using the UUID (MetroCluster)
Request
curl -X DELETE https://<mgmt-ip>/api/cluster/mediators/{uuid} -H "Content-Type: application+hal/json" -d '{"user": "username", "password": "password"}'
Date: Tue, 22 Sep 2020 09:13:52 GMT
Content-Length: 189
"job": {
  "uuid": "eeb71ccd-fcb3-11ea-acaf-005056bb47c1",
      "href": "/api/cluster/jobs/eeb71ccd-fcb3-11ea-acaf-005056bb47c1"
Deleting a configured mediator using the UUID (SnapMirror active sync: ONTAP Mediator, ONTAP cloud mediator)
Request
"job": {
  "uuid": "0661a77a-ff16-11ef-82a4-005056ae1bc8",
      "href": "/api/cluster/jobs/0661a77a-ff16-11ef-82a4-005056ae1bc8"
Use the link provided in the response to the DELETE request to fetch information for the delete job.
Request
curl -X GET https://<mgmt-ip>/api/cluster/jobs/eeb71ccd-fcb3-11ea-acaf-005056bb47c1
Job status response
Date: Tue, 22 Sep 2020 09:14:20 GMT
Content-Length: 316
"description": "DELETE /api/cluster/mediators/f89e8906-fca6-11ea-acaf-005056bb47c1",
"state": "running",
"start_time": "2020-09-22T05:13:52-04:00",
Final status of the Mediator DELETE job
Date: Tue, 22 Sep 2020 09:21:46 GMT
Content-Length: 396
"state": "success",
"code": 0,
"end_time": "2020-09-22T05:14:24-04:00",
Modifying a configured Mediator using the uuid
Request
curl -X PATCH https://<mgmt-ip>/api/cluster/mediators/{uuid} -H "Content-Type: application+hal/json" -d '{"use_http_proxy_local":"true", "use_http_proxy_remote":"true", "strict_cert_validation": "true"}'
Date: Thu, 06 Mar 2025 10:10:10 GMT
Content-Length: 189
"job": {
  "uuid": "3016e8e9-fa73-11ef-9d41-005056ae10ae",
      "href": "/api/cluster/jobs/3016e8e9-fa73-11ef-9d41-005056ae10ae"
Use the link provided in the response to the PATCH request to fetch information for the modify job.
Request
curl -X GET https://<mgmt-ip>/api/cluster/jobs/3016e8e9-fa73-11ef-9d41-005056ae10ae
Job status response
Date: Thu, 06 Mar 2025 10:10:22 GMT
Content-Length: 395
"description": "PATCH /api/cluster/mediators/a9a812bf-f7f8-11ef-a923-005056ae10ae",
"state": "success",
"code": 0,
"start_time": "2025-03-06T05:10:10-05:00",
"end_time": "2025-03-06T05:10:10-05:00",
