REST API reference
Retrieve JIT privilege configurations for an SVM
Retrieves the JIT privilege configurations for a specific SVM, which helps you manage and review the privilege settings efficiently.
HTTP method and endpoint
GET /security/jit-privileges/{owner.uuid}/{application}
Introduced in
ONTAP 9.17
Usage notes
Retrieves the JIT privilege configurations for an SVM.
  • security jit-privilege show
owner.uuid
string
path
True
Used to identify a cluster or an SVM.
application
string
path
True
Application name.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
application
string
The name of the application.
default_session_validity_period
string
The default session validity period on this SVM.
max_jit_validity_period
string
The maximum JIT validity period allowed on this SVM.
owner
owner
Owner name and UUID that uniquely identifies the JIT privilege global settings.
      "href": "/api/resourcelink"
  "application": "string",
  "default_session_validity_period": "PT1H",
  "max_jit_validity_period": "P90D",
  "owner": {
    "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
owner
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
