REST API reference
Retrieve all WebAuthn credentials entries
Retrieves all WebAuthn credentials entries to view the configured WebAuthn credentials associated with your system.
HTTP method and endpoint
GET /security/webauthn/credentials
Introduced in
ONTAP 9.16
  • security webauthn credentials show
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
collection_links
num_records
integer
Number of records.
records
array[webauthn_credentials]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "creation_time": "2024-08-05 22:38:55 -0400",
      "credential": {
        "id_sha": "xxxxxxxxxxxxxxxxxxxxxxebfb30f20bf6db74xxxxxxxxxxxxxxxxxxxxxxxxxx",
        "type": "string"
      "display_name": "admin",
      "index": 0,
      "last_used_time": "2024-08-05 22:48:55 -0400",
      "owner": {
        "name": "svm1",
      "public_key": {
        "algorithm": "ES-256",
        "value": "xxxxxxxxxxxxxxxxxxxxxe5sZohRRv2B10JjjALXmGRmEfFIxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxYr2+w=="
      "relying_party": {
        "id": "example.com",
        "name": "example.com"
      "scope": "string",
      "username": "admin"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
credential
id_sha
string
SHA-256 Hashed representation of Credential ID.
type
string
Credential type.
self
svm_reference
_links
_links
name
string
uuid
string
public_key
algorithm
string
Public key algorithm.
value
string
Public key value.
relying_party
id
string
Relying Party ID.
name
string
Relying Party Name.
_links
self_link
creation_time
string
Date and time indicating when this entry was created.
credential
credential
display_name
string
Display name.
index
integer
Index.
last_used_time
string
Date and time indicating when this entry was last used.
owner
svm_reference
public_key
public_key
relying_party
relying_party
scope
string
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.
username
string
Username.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
