REST API reference
Retrieve connection status between cache and origin volumes
GET /storage/flexcache/connection-status
Introduced In: 9.18
Retrieves attributes of the connection status between cache and origin volumes.
  • volume flexcache connection-status show
Learn more
svm_uuid
string
query
False
Filter by svm_uuid
node
string
query
False
Filter by node
local_fg_msid
integer
query
False
Filter by local_fg_msid
remote_volume
string
query
False
Filter by remote_volume
remote_endpoint
string
query
False
Filter by remote_endpoint
volume
string
query
False
Filter by volume
remote_cluster
string
query
False
Filter by remote_cluster
conn_state
string
query
False
Filter by conn_state
remote_svm
string
query
False
Filter by remote_svm
last_update_time
string
query
False
Filter by last_update_time
remote_svm_uuid
string
query
False
Filter by remote_svm_uuid
remote_vol_const_msid
integer
query
False
Filter by remote_vol_const_msid
svm
string
query
False
Filter by svm
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
collection_links
num_records
integer
Number of Records
records
array[connection_status]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "conn_state": "string",
      "last_update_time": "2018-06-04 19:00:00 +0000",
      "local_fg_msid": 0,
      "node": "string",
      "remote_cluster": "string",
      "remote_endpoint": "string",
      "remote_svm": "string",
      "remote_svm_uuid": "string",
      "remote_vol_const_msid": 0,
      "remote_volume": "string",
      "svm": "string",
      "svm_uuid": "string",
      "volume": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
connection_status
FlexCache Connection Status Endpoint
_links
self_link
conn_state
string
Connection Status between the Flexcache and Origin volumes.
last_update_time
string
Last update time of the connection status.
local_fg_msid
integer
The local volume's Master Set ID.
node
string
Name of the node.
remote_cluster
string
Remote cluster.
remote_endpoint
string
Remote endpoint type.
remote_svm
string
Remote volume SVM.
remote_svm_uuid
string
Remote SVM UUID.
integer
Remote volume's Master Set ID.
remote_volume
string
Remote Volume name.
svm
string
Volume SVM.
svm_uuid
string
Local SVM UUID.
volume
string
Local Volume name.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
