REST API reference
Ping the BlueXP cloud service
Pings the NetApp Console cloud service to check connectivity and ensure the service is reachable.
HTTP method and endpoint
POST /cluster/mediator-ping
Introduced in
ONTAP 9.17
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
configurable
boolean
Indicates if the ONTAP cloud mediator is configurable. This depends on whether the ping latency is within a threshold.
  • example: true
  • readOnly: 1
  • Introduced in: 9.17
  • x-nullable: true
high_latency
boolean
Indicates if the ping latency of the NetApp Console cloud server is greater than a threshold.
latency_ms
integer
Ping latency in milliseconds.
proxy_configured
boolean
Indicates if the HTTP proxy is configured on the cluster for the REST API calls to the NetApp Console cloud server.
proxy_used
boolean
Indicates if the HTTP proxy is used for the ping to the NetApp Console cloud server.
reachable
boolean
Ping status of the NetApp Console cloud service.
timeout_occurred
boolean
Indicates if the ping to the NetApp Console cloud server failed due to a timeout.
type
string
Mediator type.
Example request
  "configurable": 1,
  "high_latency": "",
  "latency_ms": 150,
  "proxy_configured": 1,
  "proxy_used": 1,
  "reachable": 1,
  "timeout_occurred": "",
  "type": "string"
Status: 200, Ok
configurable
boolean
  • example: true
  • readOnly: 1
  • x-nullable: true
high_latency
boolean
latency_ms
integer
proxy_configured
boolean
proxy_used
boolean
reachable
boolean
timeout_occurred
boolean
type
string
Mediator type.
  "configurable": 1,
  "high_latency": "",
  "latency_ms": 150,
  "proxy_used": 1,
  "reachable": 1,
  "type": "string"
Status: Default
ONTAP Error Response codes
Error code Description
13369414
Failed to talk to the NetApp Console cloud service. Check the need for an HTTP proxy and network settings, such as firewalls.
13369417
Failed to check if an HTTP proxy is configured on the cluster.
configurable
boolean
  • example: false
  • readOnly: 1
  • x-nullable: true
error
error
reachable
boolean
Example error
  "configurable": "",
  "error": {
    "message": "string"
  "reachable": ""
mediator_ping
NetApp Console cloud service ping API.
configurable
boolean
  • example: true
  • readOnly: 1
  • x-nullable: true
high_latency
boolean
latency_ms
integer
proxy_configured
boolean
proxy_used
boolean
reachable
boolean
timeout_occurred
boolean
type
string
Mediator type.
error
code
integer
Error code.
message
string
Error message string.
