Create JIT privilege user configurations for an SVM
Creates JIT privilege user configurations for an SVM to define user privileges dynamically within a storage virtual machine. This is typically used to manage user access in a flexible and secure manner.
HTTP method and endpoint
POST /security/jit-privilege-users
Introduced in
ONTAP 9.17
Required properties
owner.uuid- Account owner UUID. -
account.name- User name. -
application- Application
Related ONTAP commands
security jit-privilege user create
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
account |
The name of the user. |
application |
string |
The name of the application. |
comment |
string |
The description of the elevation rule. |
end_time |
string |
The end date and time of the JIT privilege session in UTC. |
jit_state |
string |
The current status of the rule: preactive, idle, or active. |
jit_validity |
string |
The JIT validity period on this SVM for this user. |
owner |
Owner name and UUID that uniquely identifies the JIT settings for a user. |
role |
The role the user will be elevated to. |
session_validity |
string |
The session validity period on this SVM for this user. |
start_time |
string |
The start date and time of the JIT privilege session in UTC. |
Example request
"account": {
"name": "joe.smith"
"application": "string",
"comment": "Comment text",
"end_time": "2024-11-08 11:15:31 +0000",
"jit_state": "active",
"jit_validity": "P90D",
"owner": {
"name": "svm1",
"role": {
"name": "admin"
"session_validity": "PT1H",
"start_time": "2024-11-08 10:15:31 +0000"
Status: 201, Created
num_records |
integer |
Number of records. |
records |
array[security_jit_privilege_user] |
"num_records": 1,
"records": [
"account": {
"name": "joe.smith"
"owner": {
"name": "svm1",
"role": {
"name": "admin"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default, Error
href |
string |
_links
account_reference
name |
string |
User account |
owner
name |
string |
uuid |
string |
role
name |
string |
Role name |
account |
application |
string |
comment |
string |
end_time |
string |
jit_state |
string |
jit_validity |
string |
owner |
role |
session_validity |
string |
start_time |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
