Manage data-entropy statistics
Retrieve data-entropy statistics at the volume level to assess encryption levels using an entropy algorithm. Specify the entropy_stats_type parameter for sub_hourly, hourly, or daily granularity, or obtain comprehensive statistics without it.
Overview
This API returns the percentage of data classified as encrypted using an entropy algorithm, measured at various time intervals at the volume level. If no volume UUID is specified, entropy statistics of all the volumes will be returned. The entropy_stats_type parameter can be used to retrieve statistics with sub_hourly, hourly, or daily granularity. Additionally, it can be used to identify intervals that exhibited high (high_enc_pct) percentages of encrypted data. If no type is specified, all types of entropy statistics will be returned for the volumes.
Retrieving volume stats
In this example, the API returns the data-entropy statistics for the volumes.
# The API:
/security/anti-ransomware/volume/entropy-stats
# The call:
curl -X GET "https://<mgmt-ip>/api/security/anti-ransomware/volume/entropy-stats" -H "accept: application/json"
# The response:
"records": [
"volume": {
"uuid": "61edb8bb-b7d1-11ef-932d-005056bbaeff",
"name": "v2"
"entropy_stats_type": "sub_hourly",
"timestamp": "2024-12-13T03:36:24-05:00",
"data_written_in_bytes": 13249687,
"encryption_percentage": 51,
"duration": "PT10M21S",
"href": "/api/security/anti-ransomware/volume/entropy-stats/61edb8bb-b7d1-11ef-932d-005056bbaeff/sub_hourly/2024-12-13T03%3A36%3A24-05%3A00"
"volume": {
"name": "v2"
"entropy_stats_type": "hourly",
"timestamp": "2024-12-13T04:16:06-05:00",
"duration": "PT1H2M36S",
"href": "/api/security/anti-ransomware/volume/entropy-stats/61edb8bb-b7d1-11ef-932d-005056bbaeff/hourly/2024-12-13T04%3A16%3A06-05%3A00"
"num_records": 20,
"href": "/api/security/anti-ransomware/volume/entropy-stats/61edb8bb-b7d1-11ef-932d-005056bbaeff"
