REST API reference
Manage external-role-mapping entries
Use these endpoints to map roles from external identity providers to ONTAP roles, facilitating seamless integration and access control within your environment.
Overview
This API is used to map external identity provider roles to ONTAP roles. The POST request creates an external role to ONTAP role mapping. Various responses are shown in the examples below.
Creating an external role to ONTAP role mapping entry
The following output shows how to create an external role to ONTAP role mapping entry.
# The API
/api/security/external-role-mappings
# The call:
curl -X POST "https://<mgmt-ip>/api/security/external-role-mappings" -d '{ "external_role": "Administrator", "ontap_role": { "name": "admin" }, "provider": "adfs", "comment": "Admin role" }'
Retrieving all external role to ONTAP role mapping entries
The following output shows all external role to ONTAP role mapping entries.
# The API
# The call:
curl -X GET "https://<mgmt-ip>/api/security/external-role-mappings"
# The response:
 "records": [
   "provider": "adfs"
 "num_records": 1
