REST API reference
Manage group-to-role mapping entries
Use these endpoints to manage and map groups to ONTAP roles. Create and retrieve group-to-role mappings to define access levels and permissions within your ONTAP environment.
Overview
This API is used to manage and map groups to ONTAP roles. The POST request creates a group to role mapping. Various responses are shown in the examples below.
Creating a group to role mapping entry
The following output shows how to create a group to role mapping entry.
# The API:
/api/security/group/role-mappings
# The call:
curl -X POST "https://<mgmt-ip>/api/security/group/role-mappings" -d '{ "group_id": 1, "ontap_role": { "name": "admin" }, "comment": "Group1 admin role"}'
Retrieving all group to role mapping entries
The following output shows all group to role mapping entries.
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/security/group/role-mappings"
# The response:
 "records": [
   "group_id": 1,
   "ontap_role": {
     "name": "admin"
 "num_records": 1
