Manage JIT privilege user configurations
Configure, access, and remove user-specific JIT privilege session settings using this category of endpoints. Use them to manage elevated session configurations for users with JIT-supported login methods on specific SVMs.
Overview
This API is used to create, retrieve, and delete relevant information related to user-specific JIT privilege session configurations. Prerequisites: You must create a user that has a JIT supported login method configured on the SVM that you want to create the elevated session configurations.
Creating the JIT session configuration for a user
# The API:
POST "/api/security/jit-privilege-users"
# The call:
curl -X POST "https://<mgmt-ip>/api/security/jit-privilege-users?return_records=true" -H "accept: application/hal+json" -d '{ "owner": { "name": "Cserver"} , "account": { "name": "joe"}, "application": "ssh","role": {"name": "admin"},"session_validity": "PT30M","jit_validity": "PT2H10M20S"}'
# The response:
Retrieving the configured JIT privilege sessions for users
Retrieves the JIT privilege user session configurations or a filtered list (for a specific SVM, user, etc).
# The API:
GET "/api/security/jit-privilege-users"
# The call:
curl -X GET "https://<mgmt-ip>/api/security/jit-privilege-users" -H "accept: application/hal+json"
# The response:
"records": [
"owner": {
"uuid": "b009a9e7-4081-b576-7575-ada21efcaf16",
"name": "Cserver",
"href": "/api/svm/svms/b009a9e7-4081-b576-7575-ada21efcaf16"
"account": {
"name": "testUser"
"href": "/api/security/jit-privilege-users/b009a9e7-4081-b576-7575-ada21efcaf16/testUser/ssh"
"num_records": 1,
"href": "/api/security/jit-privilege-users"
