REST API reference
View all WebAuthn supported algorithms
View the WebAuthn algorithms supported for authentication, including ECDSA and RSASSA-PKCS1 options. Use this endpoint to confirm which security algorithms are available for your WebAuthn configuration.
Overview
This API endpoint retrieves the list of supported algorithms for WebAuthn authentication.
Retrieving the list of supported algorithms
This endpoint retrieves all of the supported algorithms for WebAuthn authentication. The following table lists the supported algorithms:
Algorithm ID Algorithm Name Description
-7
ES256
ECDSA w/ SHA-256
-35
ES384
ECDSA w/ SHA-384
-257
RS256
RSASSA-PKCS1-v1_5 using SHA-256
# The API:
GET "/api/security/webauthn/supported-algorithms"
# The call to retrieve the list of supported algorithms:
curl -k https://<mgmt-ip>/api/security/webauthn/supported-algorithms
