security-certificate
security-certificate-ca-issued-get
This ONTAPI call does not have an equivalent REST API call.
security-certificate-ca-issued-get-iter
security-certificate-create
POST /api/security/certificates
Usage: This ONTAPI call can be issued against Storage VM (SVM) management LIFs.
| ONTAPI attribute | REST attribute | Comment |
cert-name |
name |
common-name |
common_name |
country |
No REST Equivalent |
email-address |
expire-days |
expiry_time |
hash-function |
hash_function |
is-system-internal-certificate |
locality |
organization |
organization-unit |
size |
key_size |
state |
type |
type |
vserver |
svm.name |
security-certificate-delete
DELETE /api/security/certificates/{uuid}
cert-name |
name |
certificate-authority |
ca |
common-name |
common_name |
serial-number |
serial_number |
subtype |
This ONTAPI attribute is deprecated as of ONTAP 9.6. No equivalent REST API is available. |
type |
type |
vserver |
svm.name |
security-certificate-delete-iter
continue-on-failure |
max-failure-count |
max-records |
max_records |
Specifies the maximum number of records to return before paging. |
cert-name |
name |
ca |
common-name |
common_name |
country |
email-address |
expiration-date |
expire-days |
expiry_time |
hash-function |
hash_function |
is-default |
is-root |
is-system-generated |
locality |
organization |
organization-unit |
protocol |
public-certificate |
public_certificate |
self-signed |
serial-number |
serial_number |
size |
key_size |
start-date |
state |
subtype |
type |
type |
vserver |
svm.name |
return-failure-list |
return-success-list |
security-certificate-file-get-iter
security-certificate-generate-csr
POST /api/security/certificate-signing-request
common-name |
subject_name |
All subject names, including common name, are supported through this field. |
country |
email-address |
hash-function |
hash_function |
locality |
organization |
organization-unit |
size |
security_strength |
Security strength in bits as opposed to "size" which is RSA-key bits. |
state |
security-certificate-get
GET /api/security/certificates/{uuid}
cert-name |
name |
ca |
common-name |
common_name |
country |
email-address |
expiration-date |
expire-days |
expiry_time |
hash-function |
hash_function |
is-default |
is-root |
locality |
organization |
organization-unit |
protocol |
self-signed |
serial-number |
serial_number |
size |
key_size |
start-date |
state |
subtype |
type |
type |
vserver |
svm.name |
security-certificate-get-iter
cert-name |
name |
ca |
common-name |
common_name |
country |
email-address |
expiration-date |
expire-days |
expiry_time |
hash-function |
hash_function |
is-default |
is-root |
locality |
organization |
organization-unit |
protocol |
self-signed |
serial-number |
serial_number |
size |
key_size |
start-date |
state |
subtype |
type |
type |
vserver |
svm.name |
max-records |
max_records |
security-certificate-install
cert-name |
name |
certificate |
common-name |
common_name |
intermediate-cert-list |
intermediate_certificates |
private-key |
private_key |
subtype |
type |
type |
vserver |
svm.name |
security-certificate-remove-precluster-cert
security-certificate-rename
security-certificate-revoke
security-certificate-sign
POST /api/security/certificates/{ca.uuid}/sign
ca-serial-number |
csr |
signing_request |
destination |
expire-days |
expiry_time |
filepassword |
format |
hash-function |
hash_function |
password |
private-key |
username |
vserver |
Not required. With the REST API, you can determine vserver by the ca.uuid resource. |
security-certificate-truststore-clear
security-certificate-truststore-load
