ONTAP ONTAPI-to-REST mapping
security-certificate
security-certificate-ca-issued-get
GET /api/security/certificates
Note: Two GET requests are used here. The first GET request filters on "root-ca" for the "type" attribute. The second GET request sets the "type" filter to "server|client" and adds a separate filter on the "ca" attribute using the set of values returned for "ca" by the first GET request.
Usage: This ONTAPI call can be issued against Storage VM (SVM) management LIFs.
ONTAPI attribute REST attribute Comment
ca-serial-number
serial_number
The value from the first GET response applies here.
certificate-authority
ca
The value is the same in both GET responses.
common-name
common_name
The value from the second GET reponse applies here.
country
No REST Equivalent
email-addr
No REST Equivalent
expiration-date
expiry_time
The value from the second GET response applies here.
locality
No REST Equivalent
organization
No REST Equivalent
organization-unit
No REST Equivalent
revocation-date
No REST Equivalent
serial-number
serial_number
state
No REST Equivalent
status
No REST Equivalent
vserver
svm.name
security-certificate-ca-issued-get-iter
ca-serial-number
serial_number
ca
common-name
common_name
country
No REST Equivalent
email-addr
No REST Equivalent
expiration-date
expiry_time
locality
No REST Equivalent
organization
No REST Equivalent
organization-unit
No REST Equivalent
revocation-date
No REST Equivalent
serial-number
serial_number
state
No REST Equivalent
status
No REST Equivalent
vserver
svm.name
max-records
max_records
Specifies the maximum number of records to return before paging.
security-certificate-create
POST /api/security/certificates
cert-name
name
common-name
common_name
country
No REST Equivalent
email-address
No REST Equivalent
expire-days
expiry_time
hash-function
hash_function
is-system-internal-certificate
No REST Equivalent
locality
No REST Equivalent
organization
No REST Equivalent
organization-unit
No REST Equivalent
size
key_size
state
No REST Equivalent
type
type
vserver
svm.name
security-certificate-delete
DELETE /api/security/certificates/{uuid}
cert-name
name
ca
common-name
common_name
No REST Equivalent
serial-number
serial_number
subtype
No REST Equivalent
This ONTAPI attribute is deprecated as of ONTAP 9.6. No equivalent REST API is available.
type
type
vserver
svm.name
security-certificate-delete-iter
continue-on-failure
No REST Equivalent
max-failure-count
No REST Equivalent
max-records
max_records
cert-name
name
ca
common-name
common_name
country
No REST Equivalent
email-address
No REST Equivalent
expiration-date
expiry_time
expire-days
No REST Equivalent
hash-function
hash_function
is-default
No REST Equivalent
is-root
No REST Equivalent
is-system-generated
No REST Equivalent
locality
No REST Equivalent
organization
No REST Equivalent
organization-unit
No REST Equivalent
protocol
No REST Equivalent
public-certificate
public_certificate
self-signed
No REST Equivalent
serial-number
serial_number
size
key_size
start-date
No REST Equivalent
state
No REST Equivalent
subtype
No REST Equivalent
type
type
vserver
svm.name
return-failure-list
No REST Equivalent
return-success-list
No REST Equivalent
security-certificate-file-get-iter
This ONTAPI call does not have an equivalent REST API call.
security-certificate-generate-csr
POST /api/security/certificate-signing-request
common-name
subject_name
All subject names, including common name, are supported through this field.
country
No REST Equivalent
email-address
No REST Equivalent
hash-function
hash_function
locality
No REST Equivalent
organization
No REST Equivalent
organization-unit
No REST Equivalent
size
security_strength
Security strength in bits as opposed to "size" which is RSA-key bits.
state
No REST Equivalent
security-certificate-get
GET /api/security/certificates/{uuid}
cert-name
name
ca
common-name
common_name
country
No REST Equivalent
email-address
No REST Equivalent
expiration-date
expiry_time
expire-days
No REST Equivalent
hash-function
hash_function
is-default
No REST Equivalent
is-root
No REST Equivalent
is-system-generated
No REST Equivalent
locality
No REST Equivalent
organization
No REST Equivalent
organization-unit
No REST Equivalent
protocol
No REST Equivalent
public-certificate
public_certificate
self-signed
No REST Equivalent
serial-number
serial_number
size
key_size
start-date
No REST Equivalent
state
No REST Equivalent
subtype
No REST Equivalent
type
type
vserver
svm.name
security-certificate-get-iter
cert-name
name
ca
common-name
common_name
country
No REST Equivalent
email-address
No REST Equivalent
expiration-date
expiry_time
expire-days
No REST Equivalent
hash-function
hash_function
is-default
No REST Equivalent
is-root
No REST Equivalent
is-system-generated
No REST Equivalent
locality
No REST Equivalent
organization
No REST Equivalent
organization-unit
No REST Equivalent
protocol
No REST Equivalent
public-certificate
public_certificate
self-signed
No REST Equivalent
serial-number
serial_number
size
key_size
start-date
No REST Equivalent
state
No REST Equivalent
subtype
No REST Equivalent
type
type
vserver
svm.name
max-records
max_records
security-certificate-install
cert-name
name
certificate
public_certificate
common-name
common_name
intermediate-cert-list
intermediate_certificates
No REST Equivalent
private-key
private_key
subtype
No REST Equivalent
type
type
vserver
svm.name
security-certificate-remove-precluster-cert
Note: The entity to which this ZAPI refers is not externally visible after cluster setup and is no longer in use by system. It is automatically deleted 24 hours after creation of the first data SVM. If a need arises to explicitly delete it, use the diagnostic "security certificate remove-precluster-cert" command.
security-certificate-rename
security-certificate-revoke
security-certificate-sign
POST /api/security/certificates/{ca.uuid}/sign
ca-serial-number
No REST Equivalent
No REST Equivalent
csr
signing_request
destination
No REST Equivalent
expire-days
expiry_time
filepassword
No REST Equivalent
format
No REST Equivalent
hash-function
hash_function
password
No REST Equivalent
private-key
No REST Equivalent
username
No REST Equivalent
vserver
No REST Equivalent
Not required. With the REST API, you can determine vserver by the ca.uuid resource.
security-certificate-truststore-clear
security-certificate-truststore-load
