ONTAP ONTAPI-to-REST mapping
security-certificate
security-certificate-ca-issued-get
This ONTAPI call does not have an equivalent REST API call.
security-certificate-ca-issued-get-iter
security-certificate-create
POST /api/security/certificates
Usage: This ONTAPI call can be issued against Storage VM (SVM) management LIFs.
ONTAPI attribute REST attribute Comment
cert-name
name
common-name
common_name
country
No REST Equivalent
email-address
No REST Equivalent
expire-days
expiry_time
hash-function
hash_function
is-system-internal-certificate
No REST Equivalent
locality
No REST Equivalent
organization
No REST Equivalent
organization-unit
No REST Equivalent
size
key_size
state
No REST Equivalent
type
type
vserver
svm.name
security-certificate-delete
DELETE /api/security/certificates/{uuid}
cert-name
name
certificate-authority
ca
common-name
common_name
No REST Equivalent
serial-number
serial_number
subtype
No REST Equivalent
This ONTAPI attribute is deprecated as of ONTAP 9.6. No equivalent REST API is available.
type
type
vserver
svm.name
security-certificate-delete-iter
continue-on-failure
No REST Equivalent
max-failure-count
No REST Equivalent
max-records
max_records
Specifies the maximum number of records to return before paging.
cert-name
name
ca
common-name
common_name
country
No REST Equivalent
email-address
No REST Equivalent
expiration-date
No REST Equivalent
expire-days
expiry_time
hash-function
hash_function
is-default
No REST Equivalent
is-root
No REST Equivalent
is-system-generated
No REST Equivalent
locality
No REST Equivalent
organization
No REST Equivalent
organization-unit
No REST Equivalent
protocol
No REST Equivalent
public-certificate
public_certificate
self-signed
No REST Equivalent
serial-number
serial_number
size
key_size
start-date
No REST Equivalent
state
No REST Equivalent
subtype
No REST Equivalent
type
type
vserver
svm.name
return-failure-list
No REST Equivalent
return-success-list
No REST Equivalent
security-certificate-file-get-iter
security-certificate-generate-csr
POST /api/security/certificate-signing-request
common-name
subject_name
All subject names, including common name, are supported through this field.
country
No REST Equivalent
email-address
No REST Equivalent
hash-function
hash_function
locality
No REST Equivalent
organization
No REST Equivalent
organization-unit
No REST Equivalent
size
security_strength
Security strength in bits as opposed to "size" which is RSA-key bits.
state
No REST Equivalent
security-certificate-get
GET /api/security/certificates/{uuid}
cert-name
name
ca
common-name
common_name
country
No REST Equivalent
email-address
No REST Equivalent
expiration-date
No REST Equivalent
expire-days
expiry_time
hash-function
hash_function
is-default
No REST Equivalent
is-root
No REST Equivalent
is-system-generated
No REST Equivalent
locality
No REST Equivalent
organization
No REST Equivalent
organization-unit
No REST Equivalent
protocol
No REST Equivalent
public-certificate
public_certificate
self-signed
No REST Equivalent
serial-number
serial_number
size
key_size
start-date
No REST Equivalent
state
No REST Equivalent
subtype
No REST Equivalent
type
type
vserver
svm.name
security-certificate-get-iter
cert-name
name
ca
common-name
common_name
country
No REST Equivalent
email-address
No REST Equivalent
expiration-date
No REST Equivalent
expire-days
expiry_time
hash-function
hash_function
is-default
No REST Equivalent
is-root
No REST Equivalent
is-system-generated
No REST Equivalent
locality
No REST Equivalent
organization
No REST Equivalent
organization-unit
No REST Equivalent
protocol
No REST Equivalent
public-certificate
public_certificate
self-signed
No REST Equivalent
serial-number
serial_number
size
key_size
start-date
No REST Equivalent
state
No REST Equivalent
subtype
No REST Equivalent
type
type
vserver
svm.name
max-records
max_records
security-certificate-install
cert-name
name
certificate
public_certificate
common-name
common_name
intermediate-cert-list
intermediate_certificates
No REST Equivalent
private-key
private_key
subtype
No REST Equivalent
type
type
vserver
svm.name
security-certificate-remove-precluster-cert
security-certificate-rename
security-certificate-revoke
security-certificate-sign
POST /api/security/certificates/{ca.uuid}/sign
ca-serial-number
No REST Equivalent
No REST Equivalent
csr
signing_request
destination
No REST Equivalent
expire-days
expiry_time
filepassword
No REST Equivalent
format
No REST Equivalent
hash-function
hash_function
password
No REST Equivalent
private-key
No REST Equivalent
username
No REST Equivalent
vserver
No REST Equivalent
Not required. With the REST API, you can determine vserver by the ca.uuid resource.
security-certificate-truststore-clear
security-certificate-truststore-load
