ONTAP ONTAPI-to-REST mapping
storage-shelf
storage-shelf-acp-configure
This ONTAPI call does not have an equivalent REST API call.
storage-shelf-acp-firmware-update
storage-shelf-acp-firmware-update-info-get
storage-shelf-acp-firmware-update-info-get-iter
storage-shelf-acp-get
GET /api/storage/shelves/{uid}?fields=acps,name
Usage: This ONTAPI call cannot be issued against Storage VM (SVM) management LIFs.
ONTAPI attribute REST attribute Comment
address
acps.address
channel
acps.channel
connection-status
acps.connection_state
corrective-action
No REST Equivalent
error-id
No REST Equivalent
error-severity
acps.error.severity
error-text
acps.error.reason.message
error-type
acps.error.type
is-enabled
acps.enabled
netmask
acps.netmask
node-name
acps.node.name
port
acps.port
subnet
acps.subnet
node-name
acps.node.name
storage-shelf-acp-module-get
storage-shelf-acp-module-get-iter
storage-shelf-drawer-get
GET /api/storage/shelves/{uid}?fields=drawers,name
disk-count
drawers.disk_count
drawer
drawers.id
error
drawers.error
firmware-a
No REST Equivalent
firmware-b
No REST Equivalent
fru-type
No REST Equivalent
is-closed
drawers.closed
is-supported
No REST Equivalent
mfg-date
No REST Equivalent
node
No REST Equivalent
part-number
drawers.part_number
path-a
No REST Equivalent
path-b
No REST Equivalent
serial-number
drawers.serial_number
shelf
name
status-a
drawers.state
ONTAPI Status → REST API State
unknown → error
normal → ok
warning → error
error → error
critical → error
status-b
drawers.state
unknown → error
normal → ok
warning → error
error → error
critical → error
vendor-name
No REST Equivalent
storage-shelf-drawer-get-iter
GET /api/storage/shelves?fields=drawers,name
disk-count
drawers.disk_count
drawer
drawers.id
error
drawers.error
firmware-a
No REST Equivalent
firmware-b
No REST Equivalent
fru-type
No REST Equivalent
is-closed
drawers.closed
is-supported
No REST Equivalent
mfg-date
No REST Equivalent
node
No REST Equivalent
part-number
drawers.part_number
path-a
No REST Equivalent
path-b
No REST Equivalent
serial-number
shelf
name
status-a
drawers.state
unknown → error
normal → ok
warning → error
error → error
critical → error
status-b
drawers.state
unknown → error
normal → ok
warning → error
error → error
critical → error
vendor-name
No REST Equivalent
max-records
max_records
Specifies the maximum number of records to return before paging.
storage-shelf-drawer-phy-get
storage-shelf-drawer-phy-get-iter
storage-shelf-drawer-slot-get
GET /api/storage/shelves?fields=bays,name
bay
bays.id
drawer
bays.drawer.id
is-installed
bays.has_disk
shelf
name
slot
bays.drawer.slot
storage-shelf-drawer-slot-get-iter
bay
bays.id
drawer
bays.drawer.id
is-installed
bays.has_disk
shelf
name
slot
bays.drawer.slot
max-records
max_records
storage-shelf-error-list-info
Note: REST API only returns error-text field of ONTAPI
shelf-name
name
storage-shelf-firmware-update
storage-shelf-firmware-update-info-get
GET /api/cluster/software
in-progress-count
nodes.firmware.shelf.in_progress_count
node
nodes.name
update-status
nodes.firmware.shelf.update_status
storage-shelf-firmware-update-info-get-iter
in-progress-count
node
nodes.name
update-status
max-records
max_records
storage-shelf-identify
PATCH /api/storage/shelves/{uid}
is-turn-led-on
location_led
ONTAPI is-turn-led-on → REST API location_led
true → on
false → off +
shelf
name
Available for GET in the REST API endpoint. For PATCH, specify the shelf's UID.
storage-shelf-info-get
boot-devices
No REST Equivalent
coin-battery
No REST Equivalent
connection-type
connection_type
cooling-fans
fans
fan-id → fans.id
fan-location → fans.location
fan-rpm → fans.rpm
fan-op-status → fans.state
comment: fan-op-status is simplified to "ok" and "error" in REST
current-sensors
current_sensors
current-sensor-id → current_sensors.id
current-sensor-location → curent_sensors.location
current-sensor-reading → current_sensors.current
current-op-status → current_sensors.state
comment: current-op-status "normal" is changed to "ok" in REST +
dimms
No REST Equivalent
disk-count
disk_count
fc-ports
No REST Equivalent
is-local-attach
local
module-type
module_type
nsm-ports
No REST Equivalent
op-status
state
ONTAPI op-status → REST API state
unknown → unknown
normal → ok
warning → error
error → error
critical → error
standby-power → error
paths
paths
controller → paths.node.name
controller-uuid → paths.node.uuid
initiator → paths.name
initiator-side-switch-port → NA
initiator-wwpn → NA
iops → NA
io-kbps → NA
port-speed → NA
target-port → NA
target-side-switch-port → NA
tpgn → NA
power-supply-units
frus
power-supply-units have frus.type of "psu"
psu-crest-factor → frus.psu.crest_factor
psu-fw-version → frus.firmware_version
psu-id → frus.id
psu-is-enabled → frus.installed
psu-location → NA
psu-op-status → frus.state
comment: psu-op-status is simplified to "ok" and "error" in REST
psu-part-number → frus.part_number
psu-power-drawn → frus.psu.power_drawn
psu-power-rating → frus.psu.power_rating
psu-reset-capable → NA
psu-serial-number → frus.serial_number
psu-type → frus.psu.model
sas-ports
No REST Equivalent
serial-number
serial_number
shelf
name
shelf-bays
bays
bay-id → bays.id
bay-has-disk → bays.has_disk
bay-op-status → bays.state
comment: bay-op-status "normal" is changed to "ok" in REST
bay-type → bays.type
shelf-errors
errors
error-id → NA
error-type → NA
error-severity → NA
shelf-component → NA
component-location → NA
error-text → errors.reason
corrective-action → NA
shelf-id
id
shelf-model
model
shelf-modules
frus
shelf-modules have frus.type of "module"
es-serial-number → frus.serial_number
is-sas-master-module → NA
is-monitor-active → NA
module-fru-id → NA
module-fw-progress → NA
module-fw-revision → frus.firmware_version
module-id → frus.id
comment: module-id ("A" or "B") is converted to 0 or 1 in REST
module-is-reporting-element → NA
module-latest-fw-revision → NA
module-location → NA
module-op-status → frus.state
comment: module-op-status is simplified to "ok" and "error" in REST
module-part-number → frus.part_number
module-swap-count → NA
module-type → NA
shelf-uid
No REST Equivalent
stack-id
No REST Equivalent
state
No REST Equivalent
temperature-sensors
temperature_sensors
temp-sensor-id → temperature_sensors.id
temp-sensor-location → temperature_sensors.location
temp-sensor-reading → temperature_sensors.temperature
temp-is-ambient → temperature_sensors.ambient
temp-high-critical-threshold → temperature_sensors.threshold.high.critical
temp-high-warning-threshold → temperature_sensors.threshold.high.warning
temp-low-critical-threshold → temperature_sensors.threshold.low.critical
temp-low-warning-threshold → temperature_sensors.threshold.low.warning
temp-op-status → temperature_sensors.state
comment: temp-op-status "normal" is changed to "ok" in REST +
vendor-name
manufacturer.name
voltage-sensors
voltage_sensors
voltage-sensor-id → voltage_sensors.id
voltage-sensor-location → voltage_sensors.location
voltage-sensor-reading → voltage_sensors.voltage
voltage-op-status → voltage_sensors.state
comment: voltage-op-status "normal" is changed to "ok" in REST +
storage-shelf-info-get-iter
boot-devices
No REST Equivalent
coin-battery
No REST Equivalent
connection-type
connection_type
cooling-fans
fans
fan-id → fans.id
fan-rpm → fans.rpm
current-sensors
current_sensors
dimms
No REST Equivalent
disk-count
disk_count
fc-ports
No REST Equivalent
is-local-attach
local
module-type
module_type
nsm-ports
No REST Equivalent
op-status
state
unknown → unknown
normal → ok
warning → error
error → error
critical → error
paths
paths
initiator-wwpn → NA
iops → NA
io-kbps → NA
port-speed → NA
target-port → NA
tpgn → NA
power-supply-units
frus
psu-id → frus.id
psu-location → NA
sas-ports
No REST Equivalent
serial-number
serial_number
shelf
name
shelf-bays
bays
bay-id → bays.id
shelf-errors
errors
error-id → NA
error-type → NA
error-severity → NA
shelf-id
id
shelf-model
model
shelf-modules
frus
module-fru-id → NA
module-id → frus.id
module-type → NA
shelf-uid
No REST Equivalent
stack-id
No REST Equivalent
state
No REST Equivalent
temperature-sensors
temperature_sensors
vendor-name
manufacturer.name
voltage-sensors
voltage_sensors
max-records
max_records
storage-shelf-location-led-get
GET /api/storage/shelves/{uid}?fields=location_led,name,id
led-status
location_led
shelf-id
id
shelf-name
name
stack-id
No REST Equivalent
storage-shelf-location-led-get-iter
GET /api/storage/shelves?fields=location_led,name,id
led-status
location_led
shelf-id
id
shelf-name
name
stack-id
No REST Equivalent
max-records
max_records
storage-shelf-location-led-modify
led-status
location_led
shelf-name
name
storage-shelf-location-led-modify-iter
led-status
location_led
shelf-id
id
shelf-name
name
stack-id
No REST Equivalent
continue-on-failure
No REST Equivalent
max-failure-count
No REST Equivalent
max-records
max_records
return-failure-list
No REST Equivalent
return-success-list
No REST Equivalent
storage-shelf-port-get-iter
GET /api/storage/shelves?fields=ports,name
cable-end
No REST Equivalent
cable-id
ports.cable.identifier
cable-length
ports.cable.length
cable-part-number
ports.cable.part_number
cable-technology
No REST Equivalent
cable-vendor
No REST Equivalent
connector-serial-number
ports.cable.serial_number
connector-state
ports.state
connector-type
No REST Equivalent
designator
ports.designator
ONTAPI designator → REST API designator
cir → circle
sqr → square
(other) → (no change)
id
ports.id
is-cable-connected
No REST Equivalent
is-error
No REST Equivalent
is-internal
ports.internal
location
No REST Equivalent
mac
ports.mac_address
module-id
ports.module_id
remote-chassis
ports.remote.chassis
remote-device
ports.remote.device
remote-mac
ports.remote.mac_address
remote-phy
ports.remote.phy
remote-port
ports.remote.port
remote-wwn
ports.remote.wwn
shelf
name
swap-count
No REST Equivalent
wwn
ports.wwn
max-records
max_records
