storage-shelf
storage-shelf-acp-configure
This ONTAPI call does not have an equivalent REST API call.
storage-shelf-acp-firmware-update
storage-shelf-acp-firmware-update-info-get
storage-shelf-acp-firmware-update-info-get-iter
storage-shelf-acp-get
storage-shelf-acp-module-get
storage-shelf-acp-module-get-iter
storage-shelf-drawer-get
GET /api/storage/shelves/{uid}?fields=drawers,name
| ONTAPI attribute | REST attribute | Comment |
disk-count |
drawers.disk_count |
drawer |
drawers.id |
error |
drawers.error |
firmware-a |
No REST Equivalent |
firmware-b |
fru-type |
is-closed |
drawers.closed |
is-supported |
mfg-date |
node |
part-number |
drawers.part_number |
path-a |
path-b |
serial-number |
drawers.serial_number |
shelf |
name |
status-a |
drawers.state |
REST state is mapped from worse of ONTAPI status-a and status-b. + ONTAPI Status -> REST State + unknown -> error + normal -> ok + warning -> error + error -> error + critical -> error |
status-b |
drawers.state |
vendor-name |
storage-shelf-drawer-get-iter
GET /api/storage/shelves?fields=drawers,name
disk-count |
drawer |
drawers.id |
error |
drawers.error |
firmware-a |
firmware-b |
fru-type |
is-closed |
drawers.closed |
is-supported |
mfg-date |
node |
part-number |
path-a |
path-b |
serial-number |
shelf |
name |
status-a |
drawers.state |
status-b |
drawers.state |
vendor-name |
max-records |
max_records |
The maximum number of records to return before paging |
storage-shelf-drawer-phy-get
storage-shelf-drawer-phy-get-iter
storage-shelf-drawer-slot-get
storage-shelf-drawer-slot-get-iter
storage-shelf-error-list-info
storage-shelf-firmware-update
storage-shelf-firmware-update-info-get
GET /api/cluster/software
in-progress-count |
nodes.firmware.shelf.in_progress_count |
node |
nodes.name |
update-status |
nodes.firmware.shelf.update_status |
storage-shelf-firmware-update-info-get-iter
in-progress-count |
node |
nodes.name |
update-status |
max-records |
max_records |
storage-shelf-identify
storage-shelf-info-get
boot-devices |
coin-battery |
connection-type |
connection_type |
cooling-fans |
current-sensors |
dimms |
disk-count |
disk_count |
fc-ports |
is-local-attach |
local |
module-type |
module_type |
nsm-ports |
op-status |
state |
ONTAPI op-status → REST state |
paths |
paths |
power-supply-units |
frus |
sas-ports |
serial-number |
serial_number |
shelf |
name |
shelf-bays |
bays |
shelf-errors |
shelf-id |
id |
shelf-model |
model |
shelf-modules |
frus |
shelf-uid |
stack-id |
state |
temperature-sensors |
vendor-name |
voltage-sensors |
storage-shelf-info-get-iter
boot-devices |
coin-battery |
connection-type |
connection_type |
cooling-fans |
current-sensors |
dimms |
disk-count |
disk_count |
fc-ports |
is-local-attach |
local |
module-type |
module_type |
nsm-ports |
op-status |
state |
paths |
paths |
frus |
sas-ports |
serial-number |
serial_number |
shelf |
name |
shelf-bays |
bays |
shelf-errors |
shelf-id |
id |
shelf-model |
model |
shelf-modules |
frus |
shelf-uid |
stack-id |
state |
vendor-name |
voltage-sensors |
max-records |
max_records |
storage-shelf-location-led-get
storage-shelf-location-led-get-iter
storage-shelf-location-led-modify
storage-shelf-location-led-modify-iter
storage-shelf-port-get-iter
GET /api/storage/shelves?fields=ports,name
cable-end |
cable-id |
ports.cable.identifier |
cable-length |
ports.cable.length |
cable-part-number |
ports.cable.part_number |
cable-technology |
cable-vendor |
connector-serial-number |
ports.cable.serial_number |
connector-state |
ports.state |
connector-type |
designator |
ports.designator |
ONTAPI designator → REST designator |
id |
ports.id |
is-cable-connected |
is-error |
is-internal |
ports.internal |
location |
mac |
ports.mac_address |
module-id |
ports.module_id |
remote-chassis |
ports.remote.chassis |
remote-device |
ports.remote.device |
remote-mac |
ports.remote.mac_address |
remote-phy |
ports.remote.phy |
remote-port |
ports.remote.port |
remote-wwn |
ports.remote.wwn |
shelf |
name |
swap-count |
wwn |
ports.wwn |
max-records |
max_records |
