storage-shelf
storage-shelf-acp-configure
This ONTAPI call does not have an equivalent REST API call.
storage-shelf-acp-firmware-update
storage-shelf-acp-firmware-update-info-get
storage-shelf-acp-firmware-update-info-get-iter
storage-shelf-acp-get
GET /api/storage/shelves/{uid}?fields=acps,name
Usage: This ONTAPI call cannot be issued against Storage VM (SVM) management LIFs.
| ONTAPI attribute | REST attribute | Comment |
address |
acps.address |
channel |
acps.channel |
connection-status |
acps.connection_state |
corrective-action |
No REST Equivalent |
error-id |
error-severity |
acps.error.severity |
error-text |
acps.error.reason.message |
error-type |
acps.error.type |
is-enabled |
acps.enabled |
netmask |
acps.netmask |
node-name |
acps.node.name |
port |
acps.port |
subnet |
acps.subnet |
node-name |
acps.node.name |
storage-shelf-acp-module-get
storage-shelf-acp-module-get-iter
storage-shelf-drawer-get
GET /api/storage/shelves/{uid}?fields=drawers,name
disk-count |
drawers.disk_count |
drawer |
drawers.id |
error |
drawers.error |
firmware-a |
firmware-b |
fru-type |
is-closed |
drawers.closed |
is-supported |
mfg-date |
node |
part-number |
drawers.part_number |
path-a |
path-b |
serial-number |
drawers.serial_number |
shelf |
name |
status-a |
drawers.state |
ONTAPI Status → REST API State |
status-b |
drawers.state |
vendor-name |
storage-shelf-drawer-get-iter
GET /api/storage/shelves?fields=drawers,name
disk-count |
drawer |
drawers.id |
error |
drawers.error |
firmware-a |
firmware-b |
fru-type |
is-closed |
drawers.closed |
is-supported |
mfg-date |
node |
part-number |
path-a |
path-b |
serial-number |
shelf |
name |
status-a |
drawers.state |
status-b |
drawers.state |
vendor-name |
max-records |
max_records |
Specifies the maximum number of records to return before paging. |
storage-shelf-drawer-phy-get
storage-shelf-drawer-phy-get-iter
storage-shelf-drawer-slot-get
GET /api/storage/shelves?fields=bays,name
bay |
bays.id |
drawer |
bays.drawer.id |
is-installed |
bays.has_disk |
shelf |
name |
slot |
bays.drawer.slot |
storage-shelf-drawer-slot-get-iter
bay |
bays.id |
drawer |
bays.drawer.id |
is-installed |
bays.has_disk |
shelf |
name |
slot |
bays.drawer.slot |
max-records |
max_records |
storage-shelf-error-list-info
Note: REST API only returns error-text field of ONTAPI
shelf-name |
name |
storage-shelf-firmware-update
storage-shelf-firmware-update-info-get
GET /api/cluster/software
in-progress-count |
nodes.firmware.shelf.in_progress_count |
node |
nodes.name |
update-status |
nodes.firmware.shelf.update_status |
storage-shelf-firmware-update-info-get-iter
in-progress-count |
node |
nodes.name |
update-status |
max-records |
max_records |
storage-shelf-identify
PATCH /api/storage/shelves/{uid}
is-turn-led-on |
location_led |
ONTAPI is-turn-led-on → REST API location_led |
shelf |
name |
Available for GET in the REST API endpoint. For PATCH, specify the shelf's UID. |
storage-shelf-info-get
boot-devices |
coin-battery |
connection-type |
connection_type |
cooling-fans |
fans |
fan-id → fans.id |
current-sensors |
current_sensors |
current-sensor-id → current_sensors.id |
dimms |
disk-count |
disk_count |
fc-ports |
is-local-attach |
local |
module-type |
module_type |
nsm-ports |
op-status |
state |
ONTAPI op-status → REST API state |
paths |
paths |
controller → paths.node.name |
power-supply-units |
frus |
power-supply-units have frus.type of "psu" |
sas-ports |
serial-number |
serial_number |
shelf |
name |
shelf-bays |
bays |
bay-id → bays.id |
shelf-errors |
errors |
error-id → NA |
shelf-id |
id |
shelf-model |
model |
shelf-modules |
frus |
shelf-modules have frus.type of "module" |
shelf-uid |
stack-id |
state |
temperature-sensors |
temperature_sensors |
temp-sensor-id → temperature_sensors.id |
vendor-name |
manufacturer.name |
voltage-sensors |
voltage_sensors |
voltage-sensor-id → voltage_sensors.id |
storage-shelf-info-get-iter
boot-devices |
coin-battery |
connection-type |
connection_type |
cooling-fans |
fans |
fan-id → fans.id |
current-sensors |
current_sensors |
dimms |
disk-count |
disk_count |
fc-ports |
is-local-attach |
local |
module-type |
module_type |
nsm-ports |
op-status |
state |
paths |
paths |
frus |
sas-ports |
serial-number |
serial_number |
shelf |
name |
shelf-bays |
bays |
bay-id → bays.id |
shelf-errors |
errors |
error-id → NA |
shelf-id |
id |
shelf-model |
model |
shelf-modules |
frus |
shelf-uid |
stack-id |
state |
vendor-name |
manufacturer.name |
voltage-sensors |
voltage_sensors |
max-records |
max_records |
storage-shelf-location-led-get
GET /api/storage/shelves/{uid}?fields=location_led,name,id
led-status |
location_led |
shelf-id |
id |
shelf-name |
name |
stack-id |
storage-shelf-location-led-get-iter
GET /api/storage/shelves?fields=location_led,name,id
led-status |
location_led |
shelf-id |
id |
shelf-name |
name |
stack-id |
max-records |
max_records |
storage-shelf-location-led-modify
led-status |
location_led |
shelf-name |
name |
storage-shelf-location-led-modify-iter
led-status |
location_led |
shelf-id |
id |
shelf-name |
name |
stack-id |
continue-on-failure |
max-failure-count |
max-records |
max_records |
return-failure-list |
return-success-list |
storage-shelf-port-get-iter
GET /api/storage/shelves?fields=ports,name
cable-end |
cable-id |
ports.cable.identifier |
cable-length |
ports.cable.length |
cable-part-number |
ports.cable.part_number |
cable-technology |
cable-vendor |
connector-serial-number |
ports.cable.serial_number |
connector-state |
ports.state |
connector-type |
designator |
ports.designator |
ONTAPI designator → REST API designator |
id |
ports.id |
is-cable-connected |
is-error |
is-internal |
ports.internal |
location |
mac |
ports.mac_address |
module-id |
ports.module_id |
remote-chassis |
ports.remote.chassis |
remote-device |
ports.remote.device |
remote-mac |
ports.remote.mac_address |
remote-phy |
ports.remote.phy |
remote-port |
ports.remote.port |
remote-wwn |
ports.remote.wwn |
shelf |
name |
swap-count |
wwn |
ports.wwn |
max-records |
max_records |
