tape-mc-info
tape-mc-get
GET /api/storage/tape-devices/{node.uuid}/{device_id}
Usage: This ONTAPI call cannot be issued against Storage VM (SVM) management LIFs.
| ONTAPI attribute | REST attribute | Comment |
alias-mapping |
aliases.mapping |
alias-name |
aliases.name |
block-number |
block_number |
density-formats |
formats |
description |
description |
device-id |
device_id |
device-if-type |
interface |
device-names |
device_names |
device-state |
device_state |
device-type |
type |
error |
No REST Equivalent |
file-number |
file_number |
functional-status |
initiator |
storage_port.name |
residual-count |
residual_count |
resv-type |
reservation_type |
serial-number |
serial_number |
wwnn |
wwnn |
wwnn contains ":" in ONTAPI, but not in the REST API. |
wwpn |
wwpn |
wwpn contains ":" in ONTAPI, but not in the REST API. |
node-name |
node.name |
tape-mc-get-iter
alias-mapping |
aliases.mapping |
alias-name |
aliases.name |
block-number |
block_number |
density-formats |
formats |
description |
description |
device-id |
device_id |
device-if-type |
interface |
device-names |
device_names |
device-state |
device_state |
device-type |
type |
error |
file-number |
file_number |
functional-status |
initiator |
storage_port.name |
node-name |
node.name |
residual-count |
residual_count |
resv-type |
reservation_type |
serial-number |
serial_number |
wwnn |
wwnn |
wwpn |
wwpn |
max-records |
max_records |
Specifies the maximum number of records to return before paging. |
tape-mc-info-alias-clear
PATCH /api/storage/tape-devices/{node.uuid}/{device_id}
clear-scope |
name |
aliases.name |
Remove the alias from aliases.name to clear it. |
node-name |
node.name |
tape-mc-info-alias-set
mapping |
name |
aliases.name |
Add the alias to aliases.name. |
node-name |
node.name |
tape-mc-info-offline
Note: Set online to false to take the tape device offline.
device-id |
device_id |
device-name |
node-name |
node.name |
tape-mc-info-online
Note: Set online to true to bring the tape device online.
device-id |
device_id |
device-name |
node-name |
node.name |
tape-mc-info-position
count |
position.count |
device-name |
The no-rewind device name with the current density is used. |
node-name |
node.name |
operation |
position.operation |
tape-mc-info-reset
This ONTAPI call does not have an equivalent REST API call.
tape-mc-info-test-release
tape-mc-info-test-reserve
tape-mc-info-trace
