ONTAP ONTAPI-to-REST mapping
tape-mc-info
tape-mc-get
GET /api/storage/tape-devices/{node.uuid}/{device_id}
Usage: This ONTAPI call cannot be issued against Storage VM (SVM) management LIFs.
ONTAPI attribute REST attribute Comment
alias-mapping
aliases.mapping
alias-name
aliases.name
block-number
block_number
density-formats
formats
description
description
device-id
device_id
device-if-type
interface
device-names
device_names
device-state
device_state
device-type
type
error
No REST Equivalent
file-number
file_number
functional-status
No REST Equivalent
initiator
storage_port.name
residual-count
residual_count
resv-type
reservation_type
serial-number
serial_number
wwnn
wwnn
wwnn contains ":" in ONTAPI, but not in the REST API.
wwpn
wwpn
wwpn contains ":" in ONTAPI, but not in the REST API.
node-name
node.name
tape-mc-get-iter
alias-mapping
aliases.mapping
alias-name
aliases.name
block-number
block_number
density-formats
formats
description
description
device-id
device_id
device-if-type
interface
device-names
device_names
device-state
device_state
device-type
type
error
No REST Equivalent
file-number
file_number
functional-status
No REST Equivalent
initiator
storage_port.name
node-name
node.name
residual-count
residual_count
resv-type
reservation_type
serial-number
serial_number
wwnn
wwnn
wwpn
wwpn
max-records
max_records
Specifies the maximum number of records to return before paging.
tape-mc-info-alias-clear
PATCH /api/storage/tape-devices/{node.uuid}/{device_id}
clear-scope
No REST Equivalent
name
aliases.name
Remove the alias from aliases.name to clear it.
node-name
node.name
tape-mc-info-alias-set
mapping
No REST Equivalent
name
aliases.name
Add the alias to aliases.name.
node-name
node.name
tape-mc-info-offline
Note: Set online to false to take the tape device offline.
device-id
device_id
device-name
No REST Equivalent
node-name
node.name
tape-mc-info-online
Note: Set online to true to bring the tape device online.
device-id
device_id
device-name
No REST Equivalent
node-name
node.name
tape-mc-info-position
count
position.count
device-name
No REST Equivalent
The no-rewind device name with the current density is used.
node-name
node.name
operation
position.operation
tape-mc-info-reset
This ONTAPI call does not have an equivalent REST API call.
tape-mc-info-test-release
tape-mc-info-test-reserve
tape-mc-info-trace
