Expand or contract an ONTAP Select cluster
Beginning with ONTAP Select 9.15.1, you can increase the size of an existing cluster from six to eight nodes and decrease the cluster size from eight to six nodes.
The following cluster expansions and contractions aren't supported:
Expansions from one, two, or four-node clusters to six or eight-node clusters.
Contractions from six or eight-node clusters to one, two, or four-node clusters.
To change the number of nodes in a cluster to a size that isn't supported by cluster expansion or contraction, you need to perform the following tasks:
You initiate the cluster expansion and contraction procedures from ONTAP Select Deploy using the CLI, API, or web interface.
Hardware and storage considerations
The cluster expansion and contraction functionalities are restricted in the following ways:
Support is limited to clusters created on ESX hypervisor hosts. The following ESX versions are compatible with ONTAP Select 9.15.1 and later:
ESXi 8.0 U3
ESXi 8.0 U2
ESXi 8.0 U1
ESXi 8.0 GA
ESXi 7.0 U3
ESXi 7.0
Expand the cluster
You can increase the size of an existing cluster from a six-node to an eight-node cluster with the cluster expansion feature.
In preparation for the cluster expansion procedure, new ESX hosts are added to the inventory and the details of the new nodes are assigned. Before starting the cluster expansion process, a network precheck verifies the selected internal network.
Sign in to the Deploy utility web user interface using the administrator account.
Select the Cluster tab at the top of the page and select the desired cluster from the list.
On the cluster details page, select the gear icon at the right of the page and select Expand Cluster.
Navigate to the HA Pair 4 section.
Choose the high availability (HA) pair configuration details for the fourth HA pair, including:
Instance type
Node names
Associated hypervisor hosts
Node IP addresses
Licenses
Networking configuration
Storage configuration (RAID type and storage pools)
Select Save HA Pair to save the configuration details.
Provide the ONTAP credentials, then select Expand Cluster.
Select Next and run the network pre-check by selecting Run.
The network pre-check validates that the internal network selected for the ONTAP cluster traffic is functioning correctly.
Select Expand Cluster to begin the cluster expansion process, and then select OK in the dialog box.
It can take up to 45 minutes for the cluster to be expanded.
Monitor the multi-step cluster expansion process to confirm that the cluster expanded successfully.
Refer to the Events tab for periodic updates on the operation's progress. The page is automatically refreshed at regular intervals.
After expanding the cluster, you should back up the ONTAP Select Deploy configuration data.
Contract the cluster
You can decrease the size of an existing cluster from an eight-node to a six-node cluster with the cluster contraction feature.
The desired HA pair of nodes in the cluster are selected to prepare for cluster contraction during the procedure.
On the cluster details page, select the gear icon at the right of the page, then select Contract Cluster.
Select the HA Pair configuration details for any HA Pair you want to remove and provide the ONTAP credentials, then select Contract Cluster.
It can take up to 30 minutes for the cluster to be contracted.
Monitor the multi-step cluster contraction process to confirm that the cluster contracted successfully.
