ONTAP Select
Expand or contract an ONTAP Select cluster on ESXi or KVM host
Increase or decrease the cluster size of an existing ONTAP Select cluster for ESXi and KVM hypervisor hosts. For both host types, you can increase and decrease the cluster size in increments between four and twelve nodes.
The following cluster expansions and contractions aren't supported for ESXi and KVM hosts:
  • Expansions from one or two-node clusters to six, eight, ten, or twelve-node clusters.
  • Contractions from six, eight, ten, or twelve-node clusters to one or two-node clusters.
Note
To change the number of nodes in a cluster to a size that isn't supported by cluster expansion or contraction, you need to perform the following tasks:
  1. Deploy a new multi-node cluster by using the CLI or the web UI provided with the ONTAP Select Deploy administration utility.
  2. If applicable, migrate the data to the new cluster by using SnapMirror replication.
You initiate the cluster expansion and contraction procedures from ONTAP Select Deploy using the CLI, API, or web interface.
Hardware and storage considerations
The cluster expansion and contraction feature is supported on the following KVM and ESXi hypervisor hosts.
ESXi
Beginning with ONTAP Select 9.15.1, cluster expansion and contraction is supported on ESXi hypervisor hosts.
Cluster expansion and contraction is supported for the following ESXi hypervisor versions:
  • ESXi 9.0
  • ESXi 8.0 U3
  • ESXi 8.0 U2
  • ESXi 8.0 U1
  • ESXi 8.0 GA
KVM
Beginning with ONTAP Select 9.17.1, cluster expansion and contraction is supported on KVM hypervisor hosts.
Cluster expansion and contraction is supported for the following KVM hypervisor versions:
  • Red Hat Enterprise Linux (RHEL) 64-bit 10.1, 10.0, 9.7, 9.6, 9.5, 9.4, 9.3, 9.2, 9.1, 9.0, 8.8, 8.7, and 8.6
  • Rocky Linux 10.1, 10.0, 9.7, 9.6, 9.5, 9.4, 9.3, 9.2, 9.1, 9.0, 8.9, 8.8, 8.7, and 8.6
Expand the cluster
Use the cluster expansion feature to increase the size of an existing ONTAP Select cluster.
You can increase the size of an existing cluster on an ESXi or KVM host in the following increments:
  • From four nodes to six, eight, ten, or twelve nodes
  • From six nodes to eight, ten, or twelve nodes
  • From eight nodes to ten or twelve nodes
  • From ten to twelve nodes
About this task
In preparation for cluster expansion, new ESXi and KVM hosts are added to the inventory and the details of the new nodes are assigned. Before starting the cluster expansion process, a network precheck verifies the selected internal network.
Before you begin
  • When deploying a multi-node cluster, you should be familiar with the network connectivity checker. You can run the network connectivity checker using the web UI or the CLI.
  • Verify that you have the license details for the new nodes.
Steps
  1. Sign in to the Deploy utility web user interface using the administrator account.
  2. Select the Cluster tab at the top of the page and select the desired cluster from the list.
  3. On the cluster details page, select the gear icon at the right of the page and select Expand Cluster.
  4. Navigate to the HA Pair 4 section.
  5. Choose the following high availability (HA) pair configuration details for the fourth HA pair:
    • Instance type
    • Node names
    • Associated hypervisor hosts
    • Node IP addresses
    • Licenses
    • Networking configuration
    • Storage configuration (RAID type and storage pools)
  6. Select Save HA Pair to save the configuration details.
  7. Provide the ONTAP credentials, and select Expand Cluster.
  8. Select Next and run the network pre-check by selecting Run.
    The network pre-check validates that the internal network selected for the ONTAP cluster traffic is functioning correctly.
  9. Select Expand Cluster to begin the cluster expansion process, and then select OK in the dialog box.
    It can take up to 45 minutes for the cluster to be expanded.
  10. Monitor the multi-step cluster expansion process to confirm that the cluster expanded successfully.
  11. Refer to the Events tab for periodic updates on the operation's progress. The page is automatically refreshed at regular intervals.
After you finish
After expanding the cluster, you should back up the ONTAP Select Deploy configuration data.
Contract the cluster
Use the cluster contraction feature to decrease the size of an existing ONTAP Select cluster.
You can decrease the size of an existing cluster on an ESXi or KVM host in the following increments:
  • From twelve nodes to ten, eight, six, or four nodes
  • From ten nodes to eight, six, or four nodes
  • From eight to six or four nodes
  • From six to four nodes
About this task
The desired HA pair of nodes in the cluster are selected to prepare for cluster contraction during the procedure.
Steps
  3. On the cluster details page, select the gear icon at the right of the page, then select Contract Cluster.
  4. Select the HA Pair configuration details for any HA Pair you want to remove and provide the ONTAP credentials, then select Contract Cluster.
    It can take up to 30 minutes for the cluster to be contracted.
  5. Monitor the multi-step cluster contraction process to confirm that the cluster contracted successfully.
  6. Refer to the Events tab for periodic updates on the operation's progress. The page is automatically refreshed at regular intervals.
