Install the RCF on Cisco Nexus 3232C cluster switches
Install the reference configuration file (RCF) on Cisco Nexus 3232C cluster switches after initial setup. The RCF defines port assignments and network settings required for cluster operation.
Verify the following installations and connections:
A current backup of the switch configuration.
A fully functioning cluster (no errors in the logs or similar issues).
The current RCF.
A console connection to the switch, required when installing the RCF.
The procedure requires the use of both ONTAP commands and Cisco Nexus 3000 Series Switches commands; ONTAP commands are used unless otherwise indicated.
No operational inter-switch link (ISL) is needed during this procedure. This is by design because RCF version changes can affect ISL connectivity temporarily. To enable non-disruptive cluster operations, the following procedure migrates all of the cluster LIFs to the operational partner switch while performing the steps on the target switch.
Be sure to complete the procedure in Prepare to install NX-OS and RCF, and then follow the steps below.
Step 1: Install the RCF on the switches
Login to switch cs2 using SSH or by using a serial console.
Copy the RCF to the bootflash of switch cs2 using one of the following transfer protocols: FTP, TFTP, SFTP, or SCP. For more information on Cisco commands, refer to the appropriate guide in the Cisco Nexus 3000 Series NX-OS Command Reference.
Show example
This example shows TFTP being used to copy an RCF to the bootflash on switch cs2:
cs2# copy tftp: bootflash: vrf management Enter source filename: Nexus_3232C_RCF_v1.6-Cluster-HA-Breakout.txt Enter hostname for the tftp server: 172.22.201.50 Trying to connect to tftp server......Connection to Server Established. TFTP get operation was successful Copy complete, now saving to disk (please wait)...
Apply the RCF previously downloaded to the bootflash.
Show example
This example shows the RCF file
Nexus_3232C_RCF_v1.6-Cluster-HA-Breakout.txtbeing installed on switch cs2:cs2# copy Nexus_3232C_RCF_v1.6-Cluster-HA-Breakout.txt running-config echo-commands
Make sure to read thoroughly the Installation notes, Important Notes, and banner sections of your RCF. You must read and follow these instructions to ensure the proper configuration and operation of the switch.
Examine the banner output from the
show banner motdcommand. You must read and follow the instructions under Important Notes to make sure the proper configuration and operation of the switch. -
Verify that the RCF file is the correct newer version:
show running-configWhen you check the output to verify you have the correct RCF, make sure that the following information is correct:
The RCF banner
The node and port settings
Customizations
The output varies according to your site configuration. Check the port settings and refer to the release notes for any changes specific to the RCF that you have installed.
Reapply any previous customizations to the switch configuration. Refer to Review cabling and configuration considerations for details of any further changes required.
Save basic configuration details to the
write_erase.cfgfile on the bootflash.Make sure to configure the following: * Username and password * Management IP address * Default gateway * Switch name
cs2# show run | section "switchname" > bootflash:write_erase.cfgcs2# show run | section "hostname" >> bootflash:write_erase.cfgcs2# show run | i "username admin password" >> bootflash:write_erase.cfgcs2# show run | section "vrf context management" >> bootflash:write_erase.cfgcs2# show run | section "interface mgmt0" >> bootflash:write_erase.cfg -
When installing RCF version 1.12 and later, run the following commands:
cs2# echo "hardware access-list tcam region racl-lite 512" >> bootflash:write_erase.cfgcs2# echo "hardware access-list tcam region qos 256" >> bootflash:write_erase.cfgRefer to the Knowledge Base article How to clear configuration on a Cisco interconnect switch while retaining remote connectivity for further details.
Verify that the
write_erase.cfgfile is populated as expected:show file bootflash:write_erase.cfg -
Issue the
write erasecommand to erase the current saved configuration:cs2# write eraseWarning: This command will erase the startup-configuration.Do you wish to proceed anyway? (y/n) [n] y -
Copy the previously saved basic configuration into the startup configuration.
cs2# copy bootflash:write_erase.cfg startup-config -
Reboot switch cs2:
cs2# reloadThis command will reboot the system. (y/n)? [n] y -
Repeat Steps 1 to 12 on switch cs1.
Connect the cluster ports of all nodes in the ONTAP cluster to switches cs1 and cs2.
Step: 2: Verify the switch connections
Verify that the switch ports connected to the cluster ports are up.
show interface brief | grep upShow example
cs1# show interface brief | grep up . . Eth1/1/1 1 eth access up none 10G(D) -- Eth1/1/2 1 eth access up none 10G(D) -- Eth1/7 1 eth trunk up none 100G(D) -- Eth1/8 1 eth trunk up none 100G(D) -- . .
Verify that the ISL between cs1 and cs2 is functional:
show port-channel summaryShow example
cs1# show port-channel summary Flags: D - Down P - Up in port-channel (members) I - Individual H - Hot-standby (LACP only) s - Suspended r - Module-removed b - BFD Session Wait S - Switched R - Routed U - Up (port-channel) p - Up in delay-lacp mode (member) M - Not in use. Min-links not met -------------------------------------------------------------------------------- Group Port- Type Protocol Member Ports Channel -------------------------------------------------------------------------------- 1 Po1(SU) Eth LACP Eth1/31(P) Eth1/32(P) cs1# -
Verify that the cluster LIFs have reverted to their home port:
network interface show -role clusterShow example
cluster1::*> network interface show -role cluster Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ------------------ ---------- ------------------ ------------------- ------- ---- Cluster cluster1-01_clus1 up/up 169.254.3.4/23 cluster1-01 e0d true cluster1-01_clus2 up/up 169.254.3.5/23 cluster1-01 e0d true cluster1-02_clus1 up/up 169.254.3.8/23 cluster1-02 e0d true cluster1-02_clus2 up/up 169.254.3.9/23 cluster1-02 e0d true cluster1-03_clus1 up/up 169.254.1.3/23 cluster1-03 e0b true cluster1-03_clus2 up/up 169.254.1.1/23 cluster1-03 e0b true cluster1-04_clus1 up/up 169.254.1.6/23 cluster1-04 e0b true cluster1-04_clus2 up/up 169.254.1.7/23 cluster1-04 e0b true 8 entries were displayed. cluster1::*>If any cluster LIFS have not returned to their home ports, revert them manually:
network interface revert -vserver <vserver_name> -lif <lif_name> -
Verify that the cluster is healthy:
cluster showShow example
cluster1::*> cluster show Node Health Eligibility Epsilon -------------------- ------- ------------- ------- cluster1-01 true true false cluster1-02 true true false cluster1-03 true true true cluster1-04 true true false 4 entries were displayed. cluster1::*>
Step 3: Setup your ONTAP cluster
NetApp recommends that you use System Manager to set up new clusters.
System Manager provides a simple and easy workflow for cluster set up and configuration including assigning a node management IP address, initializing the cluster, creating a local tier, configuring protocols, and provisioning initial storage.
Refer to Configure ONTAP on a new cluster with System Manager for setup instructions.
After you've installed the RCF, you can verify the SSH configuration.
