Install and maintain
Upgrade the RCF on Cisco Nexus 3232C cluster switches
Contributors netapp-yvonneo netapp-jsnyder
Upgrade the reference configuration file (RCF) on Cisco Nexus 3232C cluster switches when a newer version of the RCF is available.
Before you begin
Make sure you have the following:
  • A current backup of the switch configuration.
  • A fully functioning cluster (no errors in the logs or similar issues).
  • The current RCF.
  • If you are updating your RCF version, you need a boot configuration in the RCF that reflects the desired boot images.
    If you need to change the boot configuration to reflect the current boot images, you must do so before reapplying the RCF so that the correct version is instantiated on future reboots.
Note No operational inter-switch link (ISL) is needed during this procedure. This is by design because RCF version changes can affect ISL connectivity temporarily. To ensure non-disruptive cluster operations, the following procedure migrates all of the cluster LIFs to the operational partner switch while performing the steps on the target switch.
Caution Before installing a new switch software version and RCFs, you must erase the switch settings and perform basic configuration. You must be connected to the switch using the serial console or have preserved basic configuration information prior to erasing the switch settings.
Step 1: Prepare for the upgrade
  1. Display the cluster ports on each node that are connected to the cluster switches:
    network device-discovery show
    Show example
    cluster1::*> network device-discovery show
    Node/       Local  Discovered
    Protocol    Port   Device (LLDP: ChassisID)  Interface         Platform
    cluster1-01/cdp
                e0a    cs1                       Ethernet1/7       N3K-C3232C
                e0d    cs2                       Ethernet1/7       N3K-C3232C
    cluster1-02/cdp
                e0a    cs1                       Ethernet1/8       N3K-C3232C
                e0d    cs2                       Ethernet1/8       N3K-C3232C
    cluster1-03/cdp
                e0a    cs1                       Ethernet1/1/1     N3K-C3232C
                e0b    cs2                       Ethernet1/1/1     N3K-C3232C
    cluster1-04/cdp
                e0a    cs1                       Ethernet1/1/2     N3K-C3232C
                e0b    cs2                       Ethernet1/1/2     N3K-C3232C
    cluster1::*>
  2. Check the administrative and operational status of each cluster port.
    1. Verify that all the cluster ports are up with a healthy status:
      network port show –role cluster
      Show example
      cluster1::*> network port show -role cluster
      Node: cluster1-01
        Ignore
                                                        Speed(Mbps) Health   Health
      Port      IPspace      Broadcast Domain Link MTU  Admin/Oper  Status   Status
      e0a       Cluster      Cluster          up   9000  auto/100000 healthy false
      e0d       Cluster      Cluster          up   9000  auto/100000 healthy false
      Node: cluster1-02
        Ignore
      8 entries were displayed.
      Node: cluster1-03
         Ignore
      e0a       Cluster      Cluster          up   9000  auto/10000 healthy  false
      e0b       Cluster      Cluster          up   9000  auto/10000 healthy  false
      Node: cluster1-04
        Ignore
      cluster1::*>
    2. Verify that all the cluster interfaces (LIFs) are on the home port:
      network interface show -role cluster
      Show example
      cluster1::*> network interface show -role cluster
                  Logical            Status     Network           Current      Current Is
      Vserver     Interface          Admin/Oper Address/Mask      Node         Port    Home
      Cluster
                  cluster1-01_clus1  up/up     169.254.3.4/23     cluster1-01  e0a     true
                  cluster1-01_clus2  up/up     169.254.3.5/23     cluster1-01  e0d     true
                  cluster1-02_clus1  up/up     169.254.3.8/23     cluster1-02  e0a     true
                  cluster1-02_clus2  up/up     169.254.3.9/23     cluster1-02  e0d     true
                  cluster1-03_clus1  up/up     169.254.1.3/23     cluster1-03  e0a     true
                  cluster1-03_clus2  up/up     169.254.1.1/23     cluster1-03  e0b     true
                  cluster1-04_clus1  up/up     169.254.1.6/23     cluster1-04  e0a     true
                  cluster1-04_clus2  up/up     169.254.1.7/23     cluster1-04  e0b     true
      cluster1::*>
    3. Verify that the cluster displays information for both cluster switches:
      system cluster-switch show -is-monitoring-enabled-operational true
      Show example
      cluster1::*> system cluster-switch show -is-monitoring-enabled-operational true
      Switch                      Type               Address          Model
      cs1                         cluster-network    10.233.205.92    NX3232C
           Serial Number: FOXXXXXXXGS
            Is Monitored: true
                  Reason: None
        Software Version: Cisco Nexus Operating System (NX-OS) Software, Version
                          9.3(4)
          Version Source: CDP
      cs2                         cluster-network    10.233.205.93    NX3232C
           Serial Number: FOXXXXXXXGD
            Is Monitored: true
                  Reason: None
                          9.3(4)
          Version Source: CDP
      2 entries were displayed.
  3. Disable auto-revert on the cluster LIFs.
    cluster1::*> network interface modify -vserver Cluster -lif * -auto-revert false
Step 2: Configure ports
  1. On cluster switch cs2, shut down the ports connected to the cluster ports of the nodes.
    cs2> enable
    cs2# configure
    cs2(config)# interface eth1/1/1-2,eth1/7-8
    cs2(config-if-range)# shutdown
    cs2(config-if-range)# exit
    cs2# exit
    Caution Make sure to shutdown all connected cluster ports to avoid any network connection issues. Refer to the Knowledge Base article Node out of quorum when migrating cluster LIF during switch OS upgrade for further details.
  2. Verify that the cluster ports have failed over to the ports hosted on cluster switch cs1. This might take a few seconds.
    Show example
    Cluster
                cluster1-01_clus2 up/up      169.254.3.5/23     cluster1-01   e0a     false
                cluster1-02_clus2 up/up      169.254.3.9/23     cluster1-02   e0a     false
                cluster1-03_clus2 up/up      169.254.1.1/23     cluster1-03   e0a     false
                cluster1-04_clus2 up/up      169.254.1.7/23     cluster1-04   e0a     false
    cluster1::*>
  3. Verify that the cluster is healthy:
    cluster show
    Show example
    cluster1::*> cluster show
    Node                 Health  Eligibility   Epsilon
    cluster1-01          true    true          false
    cluster1-02          true    true          false
    cluster1-03          true    true          true
    cluster1-04          true    true          false
    4 entries were displayed.
    cluster1::*>
  4. If you have not already done so, save a copy of the current switch configuration by copying the output of the following command to a text file:
    show running-config
  5. Record any custom additions between the current running-config and the RCF file in use (such as an SNMP configuration for your organization).
  6. Save basic configuration details to the write_erase.cfg file on the bootflash.
    Note
    Make sure to configure the following: * Username and password * Management IP address * Default gateway * Switch name
    cs2# show run | section "switchname" > bootflash:write_erase.cfg
    cs2# show run | section "hostname" >> bootflash:write_erase.cfg
    cs2# show run | i "username admin password" >> bootflash:write_erase.cfg
    cs2# show run | section "vrf context management" >> bootflash:write_erase.cfg
    cs2# show run | section "interface mgmt0" >> bootflash:write_erase.cfg
  7. When upgrading to RCF version 1.12 and later, run the following commands:
    cs2# echo "hardware access-list tcam region racl-lite 512" >> bootflash:write_erase.cfg
    cs2# echo "hardware access-list tcam region qos 256" >> bootflash:write_erase.cfg
  8. Verify that the write_erase.cfg file is populated as expected:
    show file bootflash:write_erase.cfg
  9. Issue the write erase command to erase the current saved configuration:
    cs2# write erase
    Warning: This command will erase the startup-configuration.
    Do you wish to proceed anyway? (y/n) [n] y
  10. Copy the previously saved basic configuration into the startup configuration.
    cs2# copy bootflash:write_erase.cfg startup-config
  11. Reboot the switch cs2:
    cs2# reload
    This command will reboot the system. (y/n)? [n] y
  12. After the management IP address is reachable again, log in to the switch through SSH.
    You may need to update host file entries related to the SSH keys.
  13. Copy the RCF to the bootflash of switch cs2 using one of the following transfer protocols: FTP, TFTP, SFTP, or SCP. For more information on Cisco commands, refer to the appropriate guide in the Cisco Nexus 3000 Series NX-OS Command Reference.
    Show example
    This example shows TFTP being used to copy an RCF to the bootflash on switch cs2:
    cs2# copy tftp: bootflash: vrf management
    Enter source filename: Nexus_3232C_RCF_v1.6-Cluster-HA-Breakout.txt
    Enter hostname for the tftp server: 172.22.201.50
    Trying to connect to tftp server......Connection to Server Established.
    TFTP get operation was successful
    Copy complete, now saving to disk (please wait)...
  14. Apply the RCF previously downloaded to the bootflash.
    Show example
    This example shows the RCF file Nexus_3232C_RCF_v1.6-Cluster-HA-Breakout.txt being installed on switch cs2:
    cs2# copy Nexus_3232C_RCF_v1.6-Cluster-HA-Breakout.txt running-config echo-commands
    Caution
    Make sure to read thoroughly the Installation notes, Important Notes, and banner sections of your RCF. You must read and follow these instructions to ensure the proper configuration and operation of the switch.
  15. Verify that the RCF file is the correct newer version:
    show running-config
    When you check the output to verify you have the correct RCF, make sure that the following information is correct:
    • The RCF banner
    • The node and port settings
    • Customizations
      The output varies according to your site configuration. Check the port settings and refer to the release notes for any changes specific to the RCF that you have installed.
  16. Reapply any previous customizations to the switch configuration. Refer to Review cabling and configuration considerations for details of any further changes required.
  17. After you verify the RCF versions and switch settings are correct, copy the running-config file to the startup-config file.
    cs2# copy running-config startup-config [########################################] 100% Copy complete
  18. Reboot switch cs2. You can ignore the "cluster ports down" events reported on the nodes while the switch reboots.
    cs2# reload
  19. Verify the health of cluster ports on the cluster.
    1. Verify that e0d ports are up and healthy across all nodes in the cluster:
      Show example
      Node: cluster1-01
        Ignore
      Node: cluster1-02
        Ignore
      Node: cluster1-03
        Ignore
      Node: cluster1-04
        Ignore
    2. Verify the switch health from the cluster (this might not show switch cs2, since LIFs are not homed on e0d).
      Show example
      cluster1::*> network device-discovery show -protocol cdp
      cluster1-01/cdp
      cluster01-2/cdp
      cluster01-3/cdp
      cluster1-04/cdp
      cs1                         cluster-network    10.233.205.90    N3K-C3232C
            Is Monitored: true
                  Reason: None
                          9.3(4)
          Version Source: CDP
      cs2                         cluster-network    10.233.205.91    N3K-C3232C
            Is Monitored: true
                  Reason: None
                          9.3(4)
          Version Source: CDP
      Note
      You might observe the following output on the cs1 switch console depending on the RCF version previously loaded on the switch 2020 Nov 17 16:07:18 cs1 %$ VDC-1 %$ %STP-2-UNBLOCK_CONSIST_PORT: Unblocking port port-channel1 on VLAN0092. Port consistency restored. 2020 Nov 17 16:07:23 cs1 %$ VDC-1 %$ %STP-2-BLOCK_PVID_PEER: Blocking port-channel1 on VLAN0001. Inconsistent peer vlan. 2020 Nov 17 16:07:23 cs1 %$ VDC-1 %$ %STP-2-BLOCK_PVID_LOCAL: Blocking port-channel1 on VLAN0092. Inconsistent local vlan.
    Note It can take up to 5 minutes for the cluster nodes to report as healthy.
  20. On cluster switch cs1, shut down the ports connected to the cluster ports of the nodes.
    Show example
    The following example uses the interface example output from step 1:
    cs1(config)# interface eth1/1/1-2,eth1/7-8
    cs1(config-if-range)# shutdown
  21. Verify that the cluster LIFs have migrated to the ports hosted on switch cs2. This might take a few seconds.
    Show example
    Cluster
                cluster1-01_clus1  up/up      169.254.3.4/23     cluster1-01         e0d     false
                cluster1-02_clus1  up/up      169.254.3.8/23     cluster1-02         e0d     false
                cluster1-03_clus1  up/up      169.254.1.3/23     cluster1-03         e0b     false
                cluster1-04_clus1  up/up      169.254.1.6/23     cluster1-04         e0b     false
    cluster1::*>
  22. Verify that the cluster is healthy:
    cluster show
    Show example
    cluster1::*>
  23. Repeat Steps 4 to 19 on switch cs1.
  24. Enable auto-revert on the cluster LIFs.
    cluster1::*> network interface modify -vserver Cluster -lif * -auto-revert true
Step 3: Verify the cluster network configuration and cluster health
  1. Verify that the switch ports connected to the cluster ports are up.
    show interface brief | grep up
    Show example
    cs1# show interface brief | grep up
    Eth1/1/1      1       eth  access up      none                    10G(D) --
    Eth1/1/2      1       eth  access up      none                    10G(D) --
    Eth1/7        1       eth  trunk  up      none                   100G(D) --
    Eth1/8        1       eth  trunk  up      none                   100G(D) --
  2. Verify that the ISL between cs1 and cs2 is functional:
    show port-channel summary
    Show example
    cs1# show port-channel summary
    Flags:  D - Down        P - Up in port-channel (members)
            I - Individual  H - Hot-standby (LACP only)
            s - Suspended   r - Module-removed
            b - BFD Session Wait
            S - Switched    R - Routed
            U - Up (port-channel)
            p - Up in delay-lacp mode (member)
            M - Not in use. Min-links not met
    Group Port-       Type     Protocol  Member Ports
          Channel
    1     Po1(SU)     Eth      LACP      Eth1/31(P)   Eth1/32(P)
    cs1#
  3. Verify that the cluster LIFs have reverted to their home port:
    Show example
    Cluster
                cluster1-01_clus1  up/up      169.254.3.4/23     cluster1-01         e0d     true
                cluster1-02_clus1  up/up      169.254.3.8/23     cluster1-02         e0d     true
                cluster1-03_clus1  up/up      169.254.1.3/23     cluster1-03         e0b     true
                cluster1-04_clus1  up/up      169.254.1.6/23     cluster1-04         e0b     true
    cluster1::*>
    If any cluster LIFS have not returned to their home ports, revert them manually: network interface revert -vserver vserver_name -lif lif_name
  4. Verify that the cluster is healthy:
    cluster show
    Show example
    cluster1::*>
  5. Verify the connectivity of the remote cluster interfaces:
ONTAP 9.9.1 and later
You can use the network interface check cluster-connectivity command to start an accessibility check for cluster connectivity and then display the details: network interface check cluster-connectivity start and network interface check cluster-connectivity show
cluster1::*> network interface check cluster-connectivity start
NOTE: Wait for a number of seconds before running the show command to display the details.
cluster1::*> network interface check cluster-connectivity show
                                  Source              Destination         Packet
Node   Date                       LIF                 LIF                 Loss
cluster1-01
       3/5/2022 19:21:18 -06:00   cluster1-01_clus2   cluster1-02_clus1   none
       3/5/2022 19:21:20 -06:00   cluster1-01_clus2   cluster1-02_clus2   none
cluster1-02
       3/5/2022 19:21:18 -06:00   cluster1-02_clus2   cluster1-01_clus1   none
       3/5/2022 19:21:20 -06:00   cluster1-02_clus2   cluster1-01_clus2   none
cluster1-03
cluster1-04
All ONTAP releases
For all ONTAP releases, you can also use the cluster ping-cluster -node <name> command to check the connectivity: cluster ping-cluster -node <name>
cluster1::*> cluster ping-cluster -node local
Host is cluster1-03
Getting addresses from network interface table...
Cluster cluster1-03_clus1 169.254.1.3 cluster1-03 e0a
Cluster cluster1-03_clus2 169.254.1.1 cluster1-03 e0b
Cluster cluster1-04_clus1 169.254.1.6 cluster1-04 e0a
Cluster cluster1-04_clus2 169.254.1.7 cluster1-04 e0b
Cluster cluster1-01_clus1 169.254.3.4 cluster1-01 e0a
Cluster cluster1-01_clus2 169.254.3.5 cluster1-01 e0d
Cluster cluster1-02_clus1 169.254.3.8 cluster1-02 e0a
Cluster cluster1-02_clus2 169.254.3.9 cluster1-02 e0d
Local = 169.254.1.3 169.254.1.1
Remote = 169.254.1.6 169.254.1.7 169.254.3.4 169.254.3.5 169.254.3.8 169.254.3.9
Cluster Vserver Id = 4294967293
Ping status:
Basic connectivity succeeds on 12 path(s)
Basic connectivity fails on 0 path(s)
Detected 9000 byte MTU on 12 path(s):
    Local 169.254.1.3 to Remote 169.254.1.6
    Local 169.254.1.3 to Remote 169.254.1.7
    Local 169.254.1.3 to Remote 169.254.3.4
    Local 169.254.1.3 to Remote 169.254.3.5
    Local 169.254.1.3 to Remote 169.254.3.8
    Local 169.254.1.3 to Remote 169.254.3.9
    Local 169.254.1.1 to Remote 169.254.1.6
    Local 169.254.1.1 to Remote 169.254.1.7
    Local 169.254.1.1 to Remote 169.254.3.4
    Local 169.254.1.1 to Remote 169.254.3.5
    Local 169.254.1.1 to Remote 169.254.3.8
    Local 169.254.1.1 to Remote 169.254.3.9
Larger than PMTU communication succeeds on 12 path(s)
RPC status:
6 paths up, 0 paths down (tcp check)
6 paths up, 0 paths down (udp check)
What's next?
After you've upgraded your RCF, you can verify the SSH configuration.
