Install and maintain
Configuration workflow for Cisco Nexus 9332D-GX2B switches
Contributors netapp-lisa netapp-jsnyder
Follow this workflow to configure Cisco Nexus 9332D-GX2B switches for AFX 1K or AFX 2K system installations, switch replacements, or when resetting a switch to factory default settings.
You might be directed to this workflow or to individual topics in this workflow as needed by your specific procedure for Install and set up a new AFX 1K or AFX 2K system, Replace a switch, or Reset a switch to factory default settings.
After you power on the switches, they begin to boot and enter the configuration wizard. You are prompted to provide answers to a series of questions to perform the initial (startup) configuration of the switches.
Review cabling and configuration requirements.
Install the current version of NX-OS on the switches that supports your AFX 1K or AFX 2K system.
Install the current version of RCF on the switches that supports your AFX 1K or AFX 2K system. The link brings you to the RCF install or upgrade overview topic, which has information you need to know before you install the RCF.
Verify SSH is enabled so that you can use the Ethernet switch health monitor (CSHM) log collection feature.
Configure the Ethernet switch health monitoring (CSHM) to ensure the operational health of your switches and for the collection of switch logs for debugging and troubleshooting.
ONTAP supports Ethernet switch health monitoring (CSHM) to monitor the AFX cluster switches, as well as the ability to collect switch diagnostic logs. Cisco's Smart Call Home is an option to provide proactive support and help you resolve any issues that might arise with the switches.
What's next?
  • If you configured your switch as part of a new AFX 1K or AFX 2K system installation, you must complete the AFX system setup.
  • If you configured your switch as part of a switch replacement or you reset the switch to factory default settings, your switch should be operating normally.
