Install and maintain
Hardware installation workflow for Cisco Nexus 9336C-FX2 and 9336C-FX2-T storage switches
Contributors netapp-yvonneo netapp-jsnyder
Follow this workflow to install and configure the hardware for Cisco Nexus 9336C-FX2 and 9336C-FX2-T storage switches.
The sample cabling worksheet provides examples of recommended port assignments from the switches to the controllers. The blank worksheet provides a template that you can use in setting up your cluster.
Install the 9336C-FX2 and 9336C-FX2-T storage switches.
Install the 9336C-FX2 and 9336C-FX2-T switches and pass-through panel in a NetApp cabinet as required.
Before configuring your 9336C-FX2 and 9336C-FX2-T switches, review the cabling and configuration considerations.
