Overview
PDF of this doc site
Use aggregate relocation to upgrade controller hardware
Creating your file...
Your file is ready
During Stage 6, you confirm that the new nodes are set up correctly and, if the new nodes are encryption-enabled, you configure and set up Storage Encryption or NetApp Volume Encryption. You should also decommission the old nodes and resume the SnapMirror operations.
Steps
For MetroCluster FC configuration
For MetroCluster FC configuration, you must replace the disaster recovery/failover site nodes as soon as possible. Mismatch in controller models within a MetroCluster is not supported because controller model mismatch can cause disaster recovery mirroring to go offline. Use the command -skip-metrocluster-check true
option to bypass MetroCluster checks when you are replacing nodes at second site.
