Retire node2
Contributors netapp-pcarriga
To retire node2, you shut down node2 correctly and then remove it from the rack or chassis.
Steps
  1. Resume the operation:
    system controller replace resume
    The node halts automatically.
What's next?
After retiring node2, choose one of the following controller replacement procedures based on your upgrade configuration:
