Record node1 information
Contributors netapp-pcarriga netapp-aherbin
Before you can shut down and retire node1, you must record information about its cluster network, management, and FC ports as well as its NVRAM System ID. You need that information later in the procedure when you map node1 to node3 and reassign disks.
Steps
  1. Enter the following command and capture its output:
    network route show
    The system displays output similar to the following example:
     cluster::> network route show
     Vserver        Destination    Gateway      Metric
      iscsi vserver  0.0.0.0/0      10.10.50.1  20
      node1          0.0.0.0/0      10.10.20.1  10
      node2          0.0.0.0/0      192.169.1.1 20
  2. Enter the following command and capture its output:
    vserver services name-service dns show
     cluster::> vserver services name-service dns show
        Name
     Vserver        State     Domains                              Servers
     node 1 2       enabled   alpha.beta.gamma.netapp.com          10.10.60.10,
        10.10.60.20
     vs_base1       enabled   alpha.beta.gamma.netapp.com,         10.10.60.10,
                              beta.gamma.netapp.com,               10.10.60.20
     vs peer1        enabled  alpha.beta.gamma.netapp.com,         10.10.60.10,
                              gamma.netapp.com                     10.10.60.20
  3. Find the cluster network and node-management ports on node1 by entering the following command on either controller:
    network interface show -curr-node node1 -role cluster,intercluster,node-mgmt,cluster-mgmt
    The system displays the cluster, intercluster, node-management, and cluster-management LIFs for the node in the cluster, as shown in the following example:
     cluster::> network interface show -curr-node <node1>
                  Logical       Status     Network            Current  Current Is
      Vserver     Interface     Admin/Oper Address/Mask       Node     Port    Home
      vserver1
                  cluster mgmt   up/up     192.168.x.xxx/24   node1    e0c     true
      node1
                  intercluster   up/up     192.168.x.xxx/24   node1    e0e     true
                  clus1          up/up     169.254.xx.xx/24   node1    e0a     true
                  clus2          up/up     169.254.xx.xx/24   node1    e0b     true
                  mgmt1          up/up     192.168.x.xxx/24   node1    e0c     true
     5 entries were displayed.
    Note Your system might not have intercluster LIFs.
  4. Capture the information in the output of the command in Step 3 to use in the section Map ports from node1 to node3.
    The output information is required to map the new controller ports to the old controller ports.
  5. Enter the following command on node1:
    network port show -node node1 -type physical
    The system displays the physical ports on the node as shown in the following example:
     sti8080mcc-htp-008::> network port show -node sti8080mcc-htp-008 -type physical
     Node: sti8080mcc-htp-008
        Ignore
                                                Speed(Mbps)  Health   Health
     Port  IPspace  Broadcast Domain Link MTU   Admin/Oper   Status   Status
     e0M   Default  Mgmt             up   1500  auto/1000    healthy  false
     e0a   Default  Default          up   9000  auto/10000   healthy  false
     e0b   Default  -                up   9000  auto/10000   healthy  false
     e0c   Default  -                down 9000  auto/-       -        false
     e0d   Default  -                down 9000  auto/-       -        false
     e0e   Cluster  Cluster          up   9000  auto/10000   healthy  false
     e0f   Default  -                up   9000  auto/10000   healthy  false
     e0g   Cluster  Cluster          up   9000  auto/10000   healthy  false
     e0h   Default  Default          up   9000  auto/10000   healthy  false
     9 entries were displayed.
  6. Record the ports and their broadcast domains.
    The broadcast domains need to be mapped to the new ports on the new controller later in the procedure.
  7. Enter the following command on node1:
    network fcp adapter show -node node1
    The system displays the FC ports on the node, as shown in the following example:
     cluster::> fcp adapter show -node <node1>
                          Connection  Host
     Node         Adapter Established Port Address
     node1
                   0a     ptp         11400
     node1
                   0c     ptp         11700
     node1
                   6a     loop        0
     node1
                   6b     loop        0
     4 entries were displayed.
  8. Record the ports.
    The output information is required to map the new FC ports on the new controller later in the procedure.
  9. If you did not do so earlier, check whether there are interface groups or VLANs configured on node1 by entering the following commands:
    network port ifgrp show
    network port vlan show
    You will use the information in the section Map ports from node1 to node3.
  10. Take one of the following actions:
    If you…​ Then…​
    Recorded the NVRAM System ID number in the section Prepare the nodes for the upgrade.
    Go on to the next section, Retire node1.
    Did not record the NVRAM System ID number in the section Prepare the nodes for the upgrade
    Complete Step 11 and Step 12 and then continue to Retire node1.
  11. Enter the following command on either controller:
    system node show -instance -node node1
    The system displays information about node1 as shown in the following example:
     cluster::> system node show -instance -node <node1>
                                  Node: node1
                                 Owner:
                                 Model: FAS6240
                         Serial Number: 700000484678
                             Asset Tag: -
                                Uptime: 20 days 00:07
                       NVRAM System ID: 1873757983
                                Vendor: NetApp
                                Health: true
                           Eligibility: true
  12. Record the NVRAM System ID number to use in the section Install and boot node3.
