How vCenter Server RBAC works with ONTAP tools
VMware vCenter Server provides role-based access control (RBAC) that enables you to control access to vSphere objects. Understanding how vCenter Server RBAC integrates with ONTAP tools for VMware vSphere helps you manage permissions effectively and secure access to your storage resources.
Illustration of a vCenter Server permission
A permission is the foundation for enforcing access control in the vCenter Server environment. It is applied to a vSphere object and includes a user or group as part of the permission definition. The following figure shows a high-level illustration of a vCenter Server permission.
Components of a vCenter Server permission
A vCenter Server permission is a package of several components that are bound together when the permission is created.
vSphere objects
Permissions are associated with vSphere objects, such as the vCenter Server, ESXi hosts, virtual machines, datastores, data centers, and folders. Based on the object's assigned permissions, vCenter Server determines which actions or tasks can be performed on the object by each user or group. For the tasks specific to ONTAP tools for VMware vSphere, all permissions are assigned and validated at the root or root folder level of vCenter Server. See Use RBAC with vCenter server for more information.
Privileges and roles
ONTAP tools for VMware vSphere uses two types of vSphere privileges. To simplify working with RBAC in this environment, ONTAP tools provides roles containing the required native and custom privileges. The privileges include:
Native vCenter Server privileges
These are the privileges provided by vCenter Server.
ONTAP tools-specific privileges
These are custom privileges unique to ONTAP tools for VMware vSphere.
Users and groups
You can define users and groups using Active Directory or the local vCenter Server instance. Combined with a role, you can create a permission on an object in the vSphere object hierarchy. The permission grants access based on the privileges in the associated role. Roles are not assigned directly to users in isolation. Instead, users and groups gain access to an object through role privileges as part of the larger vCenter Server permission.
