Fan out protection
In a fan out protection, the consistency group is double protected with synchronous relationship on the first destination ONTAP cluster and with asynchronous relationship on the second destination ONTAP cluster. The create, edit, and delete SnapMirror active sync protection workflows maintain the synchronous protection. SRM failover and reprotect workflows maintain the asynchronous protection.
In order to establish fan out protection you need to peer three site clusters and SVMs.
Example:
If |
then |
The following diagram shows the fan out protection configuration:
Steps
Create a new place holder datastore. Refer Select a Placeholder Datastore
Add datastore to host cluster protection Modify protected host cluster. You need to add both asynchronous and synchronous policy types.
