ONTAP tools for VMware vSphere 105
Fan-out protection in ONTAP tools
Contributors netapp-revathid
In a fan-out protection scenario, the consistency group is double protected with synchronous relationship on the first destination ONTAP cluster and with asynchronous relationship on the second destination ONTAP cluster. The create, edit, and delete SnapMirror active sync protection workflows maintain the synchronous protection. VMware Live Site Recovery appliance failover and reprotect workflows maintain the asynchronous protection.
Note Fan-out is not supported for SVM users.
To set up fan-out protection, peer the three site clusters and SVMs.
Example:
If
then
  • Source consistency group is on cluster c1 and SVM svm1
  • First destination consistency group is on cluster c2 and SVM svm2 and
  • Second destination consistency group is on cluster c3 and SVM svm3
  • The cluster peering on source ONTAP cluster will be (C1, C2) and (C1, C3).
  • The cluster peering on first destination ONTAP cluster will be (C2, C1) and (C2, C3) and
  • The cluster peering on second destination ONTAP cluster will be (C3, C1) and (C3, C2).
  • SVM peering on source SVM will be (svm1, svm2) and (svm1, svm3).
  • SVM peering on first destination SVM will be (svm2, svm1) and (svm2, svm3) and
  • SVM peering on second destination svm will be (svm3, svm1) and (svm3, svm2).
The following diagram shows the fan-out protection configuration: Fan-out protection configuration Fan-out protection relationship
Steps
  1. Select a new placeholder datastore. The placeholder datastore selection criteria for phased protection are:
    • Do not place the placeholder datastore in the host cluster you are protecting.
    • If you need to include the placeholder datastore in the host cluster, add it to the VMware Live Site Recovery appliance before setting up SnapMirror active sync protection. With this setup, you can leave the placeholder datastore out of protection.
      For more information, refer to Select a Placeholder Datastore
  2. Add datastores to the host cluster protection by following Modify protected host cluster. Add both asynchronous and synchronous policy types.
