Manage authentication errors
If you do not use the Admin credentials, you might receive an authentication error after deploying the SnapCenter Plug-in for VMware vSphere or after migrating. If you encounter an authentication error, you must restart the service.
Steps
Log on to the SnapCenter VMware plug-in management GUI using the format
https://<OVA-IP-address>:8080.
Restart the service.
