Access reports
You can request reports for one or more jobs from the dashboard.
The Reports tab contains information on the jobs that are selected on the Jobs page in the Dashboard. If no jobs are selected, the Reports tab is blank.
In the left Navigator pane of the vSphere client, click Dashboard, select a vCenter Server, and then click the Reports tab.
For Backup Reports, you can do the following:
Modify the report
Click the
filter icon to modify the time range, job status type, resource groups, and policies to be included in the report. -
Generate a detailed report
Double-click any job to generate a detailed report for that job.
Optional: On the Reports tab, click Download and select the format (HTML or CSV).
You can also click the
download icon to download plug-in logs.
Types of reports from the VMware vSphere client
The VMware vSphere client for SnapCenter provides customizable report options that provide you with details about your data protection jobs and plug-in resource status. You can generate reports for primary protection only.
Backup schedules are executed in the time zone in which the SnapCenter VMware plug-in is deployed. vCenter reports data in the time zone in which the vCenter is located. Therefore, if the SnapCenter VMware plug-in and the vCenter are in different time zones, data in the VMware vSphere client Dashboard might not be the same as the data in the reports. |
The Dashboard displays information on migrated backups only after backups post-migration are performed.
| Report type | Description |
Backup Report |
Displays overview data about backup jobs. Click a section/status on the graph to see a list of jobs with that status on the Reports tab. |
Mount Report |
Displays overview data about mount jobs. Click a section/status on the graph to see a list of jobs with that status on the Reports tab. |
Restore Report |
Displays overview status information about restore jobs. Click a section/status on the graph to see a list of jobs with that status on the Reports tab. |
Last Protection Status of |
Displays overview information about the protection status, during the configured number of days, for VMs and datastores managed by the SnapCenter VMware plug-in. The default is 7 days. To modify the value in the properties file, see Modify configuration default values. |
